Ae101 battery and air filter
Postby crazor » Sat Apr 09, 2005 7:04 pm
Hey all, i have a ae101 levin
My current battery is a small sized one and i need to upgrade to one with a large cca, so here are my questions.
Without out moving the air box thing is it possible to fit a larger size battery in without have issues such as the terminals coming in contact with the bonnet?
Or would replacing the factory air intake with aftermarket provide me with more room and more ability to fit in a larger battery?
Any places people would recommend for fiting pod filters and that bizzo?
Cheers in advance
crazor
Postby Dr-X » Sat Apr 09, 2005 8:45 pm
Get one of those new little optima's, designed for jap cars.
Dr-X
Postby crazor » Sun Apr 10, 2005 11:58 am
there only 520 cca, which will not be enough for my application
crazor
Postby simonlenihan » Sun Apr 10, 2005 6:30 pm
520 CCA is a hell of alot, their CA is something around the 700 mark i believe.
What is your application?
2011 Toyota Hiace ZL
1994 BMW 740iL e38
simonlenihan
Postby minijrocks » Sun Apr 10, 2005 7:20 pm
how much should i be paying for a pod adaptor to fit silvertop?
and where is this black box everyone talks about to put a inductoin pipe through to???
minijrocks
Postby neo » Mon Apr 11, 2005 8:54 pm
You can fit a NS70 (ie light commerical truck battery) up the front in almost the factory location with a custom bracket to stop it moving.. And a 3" air intake without modifying or moving anything =)... think outside the square
neo
Postby event2 » Mon Apr 11, 2005 10:59 pm
wat the hell u need more than 500cca for?
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby simonlenihan » Mon Apr 11, 2005 11:01 pm
And CCA is measure at 0 degrees fahrenheight, thats way cold!
1994 BMW 740iL e38
simonlenihan
Postby crazor » Tue Apr 12, 2005 9:12 pm
ill be running 5.2 kw of power to my subs thats why
crazor
Postby simonlenihan » Tue Apr 12, 2005 9:15 pm
Why not just run a small optima up front, and a couple of big ones in the back?
1994 BMW 740iL e38
simonlenihan
Postby Lloyd » Tue Apr 12, 2005 9:25 pm
5.2kW... and you're expecting to only use a single battery?
Postby crazor » Thu Apr 14, 2005 10:29 pm
For the likes of sta and b u must have 1 batter in the factory location, i cant compete in the likes of ss.
Can someone please refer me to a place that can fit a pipe and pod filter to my car :)
crazor
