questions for AE85/6 4agze owners
Postby AE85.6 » Mon Apr 18, 2005 8:55 pm
hopefully one of the guys/girls that has done this already can shed some light on it for me,
My AE currently has a 4age in it, so im just trying to think of what i actually need to do the swap,
I thought i can steal any rwd bits i need from my existing engine,
so if i get a engine and computer what else would i need ?
do the two engines run different looms or can i just swap the computers ?
also if i was mating it up to a T50 would i have to use the 4age flywheel and clutch cause the gtz one is too big ?
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby l1ttle_d3vil » Mon Apr 18, 2005 9:16 pm
The flywheel and clutches of all the 4ag range are interchangeable as a unit. In my case the largest size fly to fit inside the T50 box is the 212mm (8-3/8") AE101 (20v) flywheel. Thats ok with me as when I bought my 20V motor I made sure I got the 20V flywheel with it. I am using the AE86 clutch and presure plate on this flywheel
If you have removed the flywheel for some reason the correct torque setting for the 8 bolts when doing it back up is 51-58 ft/lb (700-800 kg/cm) and for the clutch to the flywheel the 6 bolts should be torqued up to about 20-25 ft/lb.
Postby AE85.6 » Mon Apr 18, 2005 9:29 pm
oh ok cool so i can use AE86 clutch and pressure plate with the gtz flywheel ?
AE85.6
Postby Rick » Mon Apr 18, 2005 10:25 pm
AE85.6 wrote:oh ok cool so i can use AE86 clutch and pressure plate with the gtz flywheel ?
The 224 mm 4AGZE clutch and flywheel will not fit inside the T-50 bell housing, and the 224 mm clutch plate has a larger diameter spline than the T-50 input shaft
Postby fangsport » Mon Apr 18, 2005 10:50 pm
..and a T-50 won't last very long if it is turbo/supercharged. see if you can find W- series box.
fangsport
Postby Rick » Mon Apr 18, 2005 10:52 pm
fangsport wrote:..and a T-50 won't last very long if it is turbo/supercharged. see if you can find W- series box.
The W series would be great but those custom bellhousings for them are not cheap
Postby Zak » Mon Apr 18, 2005 11:16 pm
Neither are the T50 bell housings though.
Zak
Postby AE85.6 » Tue Apr 19, 2005 1:28 pm
ye i know a w series would be good but i have 2 t-50s so i want to use them first, possibly a w series after that and when more power would come into it.
ah ye i didnt rear that post correctly the first time, ok so i should source a 20v fly wheel for it then and use a heavier AE86 clutch and pressure plate, i dont want to go too silly with heavy duty bits as id rather a little slip than absolute grip with gearbox destruction :wink:
AE85.6
Postby Mr Revhead » Tue Apr 19, 2005 1:47 pm
sell the t50s to pay for the w5#... otherwise youll kil 2 t50s and still have to pay for a w5# set up....2 t50s and a bellhousing will pay for the swap!
the looms and ecu are completly different. you cant interchange
Postby suberimakuri » Wed Apr 20, 2005 12:52 am
I agree with Revhead, sell the two t50s with A bellhousings and should cover swap to W.
Then you can run the big clutch and not have to worry about slip.
You've already got it all there.
suberimakuri
Postby AE85.6 » Wed Apr 20, 2005 5:18 pm
hmm i see,
what were nite parts housings for this worth wasnt it like $700 or something Karl ? i dont know much about the different W series box's either dont they come with different position shifters too ? and the w55 57 or 58 ? are they just different ratios ?
AE85.6
Postby suberimakuri » Wed Apr 20, 2005 7:20 pm
$749 RRP for nite parts bellhousing. - brendan@niteparts.co.nz
Yeah, the different numbers are for different ratios, however, it's really all about getting the right shifter for the car, and a better condition box is better then one that has slightly different ratios for most ppl IMHO.
so, try for mid shifter or, mid-rear (commonly called rear) shifter.
suberimakuri
Postby AE85.6 » Sat Apr 23, 2005 2:32 pm
ah i see, is that just so it will come thru the floor in a suitable spot ? and what is the deal with the numbers the higher the number the bigger the ratio or ? e.g W55 smaller ratio than W58 ? also anyone have a ruff idea what sorta cash one of these boxs have been going for lately ?
AE85.6
Postby evil_si » Sat Apr 23, 2005 6:36 pm
i picked up a mint w55 for $200 and im running that behind a turbo ze in a ke30,
i had but sold a T50, with 4a bellhousing, g/box mount, driveshaft etc for around $700 on trademe :lol: , pretty much paid for the w series conversion,
the looms are different, so you cant just plug the ecu,
depending on what 4age loom and what 4agze ecu you have, if you found the corrrect pinouts for that loom and ecu, change the pin locations to suit the ecu, :?
sounds confusing, it is.
evil_si
Postby JamesM » Sun Apr 24, 2005 3:56 am
yea you will find a good one for about 250.
ratios for the boxes:
(reverse, 1,2,3,4,5)
T50 -3.484 3.587 2.022 1.384 1 0.861
W55 -4.091 3.566 2.056 1.384 1 0.850
W57 -3.768 3.285 1.894 1.275 1 0.861
W58 -3.768 3.285 1.894 1.275 1 0.783
so if u want simliar gearing to ur t50 then use w55.
the 58 will give u that extra length on 5th
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby AE85.6 » Mon Apr 25, 2005 3:12 pm
ah i see, hmm could be the way to go
AE85.6
Users browsing this forum: Google [Bot] and 28 guests
