bluetop 4age searching
Postby DXTACY » Mon Apr 25, 2005 2:36 pm
hey guys i have got my bluetop 4age runing and it warms up sweet but then when cold start is off it searches like it has an air leak
i have put new air lines on the whole engine with no succesion
took inlet piping off and checked air bypass valve, completely covered it and engine idles extreemly low but doesnt search half covered it and engine idles normal and doesnt search then with it fully uncovered it searches and makes the mega suction noise, compared noise to my mates redtop and his isnt as noisy?
could the air bypass be buggered?
any suggestions?
andrew
Lil Pimpin
Silver KP61 hatch rollin on 15 inch wires
DXTACY
Postby ChaosAD » Mon Apr 25, 2005 3:18 pm
Probably, its a common problem. and new ones arent cheap.
The valve has some sort of wax pellet in it which will be damaged if it gets too hot.
I vote some one writes a FAQ on this issue as it is quite common
ChaosAD
Postby ee904age » Mon Apr 25, 2005 3:42 pm
What sort of intake do you have? Mine make quite a loud hissing when cold, and yes its the bypass valve. Theres nothing wron with mine but it is alot more noticable with the pod setup I have.
As long as it gets quieter as the engine warms up and the idle drops, it will be ok.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby CAMB01 » Mon Apr 25, 2005 4:30 pm
hey bro i found a 4AGE Buetop throttle body last night when i was putting ma SC motor together.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby DXTACY » Mon Apr 25, 2005 4:44 pm
my intake is a rwd manifold with metal pipe then pod,
cheers for the help ill try another throttle bodyn see how it goes
Lil Pimpin
DXTACY
Postby event2 » Tue Apr 26, 2005 10:46 pm
how to fix buy $600 part from toyota or block up hole b4 throttle plate and adjust idel for when hot. runs a little ruff when cold but once warmed up its sweet.
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby sergei » Tue Apr 26, 2005 11:23 pm
what about Pick-a-Part??? Much cheaper, lots of blue tops in there (no RWD)
Postby EVLGTZ » Wed Apr 27, 2005 9:08 am
got a spare throttle body here if ya need one.
Easy enuff to just swap em over and should fix it.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby kpimpin61 » Thu Apr 28, 2005 12:11 am
hey guys i have got a spare throttle body, havent had any time to put it on yet so yer hopefully tomorrow
kpimpin61
