Gearbox Problem
Gearbox Problem
Postby SL0 R0LLA » Wed Apr 27, 2005 4:32 pm
The car doesnt move when i put it into any gear and acts like it is in neutral in every gear, still revs but doesnt move. could someone tell me what the problem is and how much it is going to cost to fix it? this just happened last night without making any noise to indicate that the gearbox broke. my car is an 87' FXGT. any help appreciated
SL0 R0LLA
Postby Adamal » Wed Apr 27, 2005 4:37 pm
Sounds like your clutch could be buggered. Has it been a slow coming process or did it just happen?
Any unusual crunching when you put it in gear?
Postby RomanV » Wed Apr 27, 2005 4:53 pm
Check your clutch fluid levels. My brothers car does exactly that when the clutch fluid runs out. (It leaks).
Either way, it sounds clutch related.
Postby Silent Knight » Wed Apr 27, 2005 5:25 pm
I had the same thing in teh supra but it was because i snapped my clutch line whilst driving and then clutch all of a sudden didn't work anymore :/
Also check the slave cylinder to see wether it might not be seized or something...this has happned to me aswell.
Otherwise your clutch might be utterly buggered. Happened numerious times with me before aswell...
Silent Knight
Postby SL0 R0LLA » Wed Apr 27, 2005 8:01 pm
Only crunches when i put it in reverse but thats when the clutch isnt in. doesnt make any noise when put into any gear when clutch is in. Yeah just happened suddenly. Where is the slave cylinder? and how do i check the clutch fluid level? sorry i dont know anything bout this kind of stuff lol
SL0 R0LLA
Postby blackmk3 » Wed Apr 27, 2005 8:48 pm
check down by the gear box were the selection cables bolt to the gearbox and c if u can move them back and forth ther shd b a little fork thing that holds the cable in, thers two cables, this happend on my old ae92
blackmk3
Postby SL0 R0LLA » Wed Apr 27, 2005 9:02 pm
Someone said something could be wrong with the selection thing, if this is the problem would it be easy to fix? dont know if it is the clutch because i should be able to still put it into gear and drive kind of?
SL0 R0LLA
clutch help maybe
Postby roadkill » Wed Apr 27, 2005 9:03 pm
there should be a fluid holder by the brake fluid thats the clutch fluid check that and if its low then top it upthat could be it, thats only if it has a hydrolic clutch. if not its cable adjust that but im preety sure they are hydrolic...if thats it then youve got a problem and you need to cange your clutch!
roadkill
Postby SL0 R0LLA » Wed Apr 27, 2005 9:42 pm
O yeah theres also some kind of smell that comes from the gearbox area.
SL0 R0LLA
Postby blackmk3 » Wed Apr 27, 2005 9:52 pm
the selection thing is a very easy fix if that is the problem but ul wana investigate....but id say if theres a smell its proberly clutch related
blackmk3
Postby Lloyd » Wed Apr 27, 2005 10:21 pm
Do you still have normal clutch pedal feel?
Postby SL0 R0LLA » Wed Apr 27, 2005 10:26 pm
Yeah still feels normal.
SL0 R0LLA
