is it possible to run a link made for a car with a distributor to run on a coil pack. Does this matter? or will it have to be sent away to link to be re-mapped. Or can this be changed just through tuning?
NEED ANSWERS AS SOON AS POSSIBLE!
RedMist wrote:No problemo Stu.
Good to see another wasted spark Link / 4ag solution. I used the WRX coilpack because its a single unit. Neater solution. But I was also pointed in the EVO coil direction. I understand both are good high output coils.
RedMist wrote:I stand corrected. The LEM3 may not be user selectable, however the 4 definately is. I have one here, and have kicked up PC Link to confirm it. I see no reason for Link to remove that function from the 5.
