Designing 2 1/2"exhaust for 4age
Postby ChaosAD » Mon May 02, 2005 9:44 pm
Due to the large cams im putting in my 4age I will be needing to upgrade my exhaust.
Im going to use 2 1/2"pipe and mandrel bends, but need advice on what type of muffler/resonators to go for that wont be too loud or restrictive.
Does anyone have any ideas?
ChaosAD
Postby Bazda » Mon May 02, 2005 10:00 pm
2 x 19" long coby resonators, and a rear N1 style muffler from actiondan.
I can take my whole system off me car and it doesnt make a difference, weird that. So must be pretty free flowing.
what cams u using?
Postby ChaosAD » Tue May 03, 2005 1:10 pm
240 deg @ .050" in 8.8mm lift
323 deg @ .050" ex 8.8mm lift
Are those long resonators the ones with the big restrictive looking expansion chambers? Those ones let the gasses expand then try and compress them back into a small pipe :?
Is your system very loud? I suppose your turbo would quieten it down a bit.
ChaosAD
Postby Bazda » Tue May 03, 2005 1:43 pm
you can get ones with or without the expansion chambers.
Yes my system is pretty loud even with the turbo.
When it was s/c it was damn loud!
Postby Loudtoy » Tue May 03, 2005 8:09 pm
Try some lukey mufflers, my apprentice boy has some on his bzg and he also has a 2 1/2 inch mandrel bent due to wanting to turbo it at some stage - sounds quite nice, quite deep and not to loud.
Thats my suggestion anyhow - i'd avoid n1 style mufflers like the plauge for a na car, to hard to get a nice sound and keep quite.
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby CozmoNz » Tue May 03, 2005 8:35 pm
Loudtoy wrote:Try some lukey mufflers, my apprentice boy has some on his bzg and he also has a 2 1/2 inch mandrel bent due to wanting to turbo it at some stage - sounds quite nice, quite deep and not to loud.
long reso's keep it nice....
quiet? why? lol :P
Rayne For President!
CozmoNz
Postby Loudtoy » Tue May 03, 2005 9:25 pm
CozmoNz wrote:quiet? why? lol :P
ChaosAD wrote: what type of muffler/resonators to go for that wont be too loud or restrictive.
Have found in my experince that 2 decent lukey mufflers using one as a reso flow extremely well whilst sounding nice without being to loud, maybe quiet wasn't quite the right word but it got my point across. Also you need at least 2 long reso's to keep the noise down as well as a decent rear muffler - all these add up to more than a decent muffler and a decent muffler used as a reso, and are more restrictive to boot!
TS Member sine 2001
Loudtoy
Postby Adamal » Tue May 03, 2005 9:35 pm
Is it just me or does 2 1/2" sound a bit too big for a 1600cc N/A engine?
I know people that won't go bigger than that on a 2 litre turbo engine...
Postby TRDWGN » Tue May 03, 2005 11:29 pm
Group N Lancer EVO III rally cars ran around 260HP (or something like that) and ran a 2inch exhaust.....
All JDM bolt on systems for 4AGE's are 2.5in....
I have just replaced my 2.5in system with a 2.25in system running into two 19in coby's (with expansion chambers however these offer no restrictions :lol: ) then it splits into twin 2 inch and out through two 2inch Holden Commodore VX V8 factory resonators (baffled not straight through, although are off a 250kw motor so offer virtually no restriction on a measly blacktop output :lol:) end result is better than my 2.5in system and factory quiet 8) plus being the one of the only twin rear mufflered AE111's around!
TRDWGN
Postby Bazda » Wed May 04, 2005 12:52 am
since u got cams and all, are u getting tuned length extractors made? with a collector and a taper coming of that at a tuned length as well.....
Postby ChaosAD » Wed May 04, 2005 1:07 pm
Yup, tuned length extractors with 2 1/2" collector.
With the cams having so much overlap I will need minimal restriction on the intake/exhaust.
TRDWGN, what sort of mufflers/reso's did your old system have?
ChaosAD
Postby TRDWGN » Wed May 04, 2005 6:30 pm
Was a Fujitsubo system that had a resonator that was about the size and shape of a cat and a rear muffler, i also added a 2.5in coby in place of cat...
Keep an eye out for HSV resonators on trademe also as they are 2.25 & 2.5in (depending on year) straight thru stainless steel with good sound damping qualities, and usually friggn cheap to buy and near perfect for a 4AGE!
TRDWGN
Postby ChaosAD » Thu Jun 16, 2005 1:17 pm
Looks like a lukey Ultra Flo http://www.rpw.com.au/Products/Exhaust%20Products/Mufflers.htm might be the go.
Any idea on when they go for? Trademe seems to be flooded with the N1 designs but piss all decent mufflers.
ChaosAD
Postby ChaosAD » Sat Jun 18, 2005 4:25 pm
bump
ChaosAD
Postby Loudtoy » Sat Jun 18, 2005 6:04 pm
It's been a while since i brought any but having talked to a few people and finding out a few things it is generally agreed that they go for around $150 each, less than some of those big bling n1 style mufflers :)
Plus they aren't overly large external dimension size wise so they are easy to fit in and keep your pipe work simple :)
TS Member sine 2001
Loudtoy
