help my trueno is starting to backfire why???
Postby shihad » Wed May 04, 2005 2:08 pm
I recently purchased a 88 trueno with a silvertop in it and its just started to backfire.the more throttle i give it the bigger it backfires.Any help would be good.
shihad
Postby ants_ae92 » Wed May 04, 2005 2:27 pm
Running rich? Common problem of all silvertops. You are talking about a 20v right?
Unburnt fuel combusts in the exhaust. Is there lots of black smoke coming out of exhaust?
Hope this helps
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby mr pad » Wed May 04, 2005 2:30 pm
Have you had a motor conversion?
Are you running any aftermarket parts ie exhaust etc?
mr pad
Postby CozmoNz » Wed May 04, 2005 2:32 pm
sure its not just a distributor screwup?
has it done it recently?
if you have water in your dizzy, it will make a hell of a popping noise.
my suggestion, pop out your dizzy cap, check for water, spray some crc in, chuck it back on, if it makes even the slightest difference, and its still happening, get a new dizzy.
Rayne For President!
CozmoNz
Postby CAMB01 » Wed May 04, 2005 8:41 pm
Check your ignition timing, spark plugs, leads etc
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby shihad » Sat May 07, 2005 6:54 pm
i brought my car with a silvertop in it (yes its a 20v).it has a autotech exhaust.I havent seen any smoke cuming out of it.any other questions.thanks 4 the help
shihad
