AE101, AE92
AE101, AE92
Postby widebodyhachi » Thu May 05, 2005 12:03 pm
Does anybody know if AE101 Super strut hubs and brakes can be bolted onto AE92 carriers
widebodyhachi
Postby Distrb » Thu May 05, 2005 12:08 pm
i honestly cant see how the hubs will bolt up without any modification
being that you're trying to mate two different setups together.
Distrb
Regular Poster
Postby Mr Revhead » Thu May 05, 2005 12:46 pm
the brakes can be made to fit.
i forget the exact details but it requires some machining.
keep the stock carriers, and use the s/s rotors and calipers.
i trust your not here with the same attitude you displayed on twincam.org
Postby boy_with_a_new_toy » Thu May 05, 2005 10:43 pm
it can be done, forget the details yet again,
how bout i dont n just say i did? mmm trd
boy_with_a_new_toy
Postby widebodyhachi » Fri May 06, 2005 3:57 pm
What machining has to be done they share the same wheel bearing its just the physical hub design that differs, dosnt it?
I was under the impressions that its all a bolt on since they share the same code for carrier but this is toyota where talking about after all
widebodyhachi
Postby Distrb » Fri May 06, 2005 4:24 pm
its easier and cheaper to machine the disc and calliper to suit the non super strut hub than attempt to modify the superstrut hub to suit the macpherson setup..
Distrb
Regular Poster
Postby Mr Revhead » Fri May 06, 2005 5:03 pm
as i said iv forgotten the exact detasil, but i think its jus a minor job to mount the caliper.... ill look into further....
