mr pad wrote:What size wheels do you have?
I had 16's on a ae92 levin and 4000rpm at 110kph was right on.
JT wrote:mr pad wrote:What size wheels do you have?
It's the circumference of the tires that you need to work out. Just cause you had 16's doesn't mean alot unless we know the profile and width too.
4000rpm sounds like the tires are a bit small, most tacho's tend to over-read too.
TRD Man wrote:The correct ratio for your car is 4.312 and by my calculations if you had 185/60-14 tyres you'd be pulling about 3500 rpm at 110k.
mr pad wrote:Whats actually wrong with your box?
