what gearbox to use
what gearbox to use
Postby Silvergun » Fri May 06, 2005 1:54 pm
what gearbox can i fit onto ae92 4age corolla that has a lower diff ratio?
Basically my gearbox is stuffed and i wana put something in that will make it rev lower in 5th gear as i cant stand it revving at close to 4k when only doing 110kph.
Are there any boxes that will bolt straight on and achieve what i want?
AE92 4age Redtop
Silvergun
Postby sidewz » Fri May 06, 2005 3:46 pm
would the box off a 4afe fit?
sidewz
Postby TRD Man » Fri May 06, 2005 4:14 pm
Silvergun,
If you're pulling 4000rpm to go 110kph you could have either a slipping clutch, the wrong size wheels or a gearbox with a 4.8 final drive ratio.
The correct ratio for your car is 4.312 and by my calculations if you had 185/60-14 tyres you'd be pulling about 3500 rpm at 110k.
Different brand tyres do have different circumferences and there's a wear & presure factor that could come into it as well.
Do you know how to work out the final ratio in your gearbox? If you want help I'm happy to assist. Give me a call or send a pm.
Bruce
TRD Man
Postby mr pad » Fri May 06, 2005 4:46 pm
What size wheels do you have?
I had 16's on a ae92 levin and 4000rpm at 110kph was right on.
3500at 100kph. You could just do the speed limit. Don't worry about it too much its not going to hurt you motor, 4000rpm isn't high for a 4age. I did heaps of open road kays (at 4000ishrpm) and it never skipped a beat.
Whats actually wrong with your box?
mr pad
Postby Malcolm » Fri May 06, 2005 5:21 pm
except that if you're taking the speed off your speedo, then it wont change no matter what size wheels/tyres you have on it, as the speedo assumes tyre size (well, it was built with a certain constant to convert from final drive speed to wheel speed, based on standard size wheels).
Postby JT » Fri May 06, 2005 5:23 pm
mr pad wrote:What size wheels do you have?
It's the circumference of the tires that you need to work out. Just cause you had 16's doesn't mean alot unless we know the profile and width too.
4000rpm sounds like the tires are a bit small, most tacho's tend to over-read too.
JT
Postby mr pad » Fri May 06, 2005 5:40 pm
Ok good to know, was just giving my wheels as a guide though, can't remember what the size was, 195 x somthing x 16 duhh.
mr pad
Postby Silvergun » Tue May 10, 2005 11:18 am
TRD Man wrote:The correct ratio for your car is 4.312 and by my calculations if you had 185/60-14 tyres you'd be pulling about 3500 rpm at 110k.
double checked this mornig wheel size is 185/60/14, 3800rpm 110kph.
mr pad wrote:Whats actually wrong with your box?
2nd and 3rd synchros are pretty wasted. Seems it's be cheaper to get a second hand box than get the synchros fixed on current box.
Does the 4afe have lower ratio? would it bolt straight on??
AE92 4age Redtop
Silvergun
Postby AceSniper » Tue May 10, 2005 11:30 am
A c50 from a jap 4afe prolly will... look up the spec's on google
your box is prolly a C52
AceSniper
Postby Lanius » Tue May 10, 2005 1:25 pm
Sorry to hijack the thread but can anyone tell me the model of gearbox in the Corolla FX ZI? Its a 5A-FHE according to the plate in the engine bay ...
Lanius
Postby Alex B » Tue May 10, 2005 7:24 pm
look at trans/axel on that same plate.
Postby Lanius » Tue May 10, 2005 9:42 pm
Sweet, thx bro, will get flatmate to check it out tomorrow :)
Lanius
Postby quinny » Tue May 10, 2005 9:49 pm
Just done this swap 4age box sits 500rpm higher to do a hunner k's so the FE is the percy box of choice.
FE 3000rpm @ 100
Ge 3500rpm @ 100
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby thaphatty » Tue May 10, 2005 10:10 pm
yerr, i have a 4afe 101, ever so slightly over 3000rpm @ 100ks, 3400@110ks
thaphatty
Postby Silvergun » Wed May 11, 2005 12:21 am
thanks guys, i like what i hear.
will sort out a box from a wreckers. anyone know a cheap place in wellington region that does them?
Toyota dismantlers in petone want about $270 for a 4age gearbox and they guarantee that its in good condition. Im guessing the 4afe C50 will be similar price from them.
AE92 4age Redtop
Silvergun
Postby quinny » Thu May 12, 2005 1:32 am
I deal with those guys all the time and i dont reckon thats too nasty, i have had motors, boxes, struts etc etc from them and never had a problem with anything so you get peace of mind, i would tell them that 250 in fold sounds better to me!
quinny
Postby Silvergun » Thu May 12, 2005 8:40 pm
Went to the wreckers today - $225 for 4afe box. Looks like il get it done in next couple of weeks.
Anyone sugeest anywhere in hutt valley/wellington that is good for replacing gearboxes?
Would give it a go myself but im likely to mess something up and itll end up costing me more anyway.
AE92 4age Redtop
Silvergun
Postby quinny » Fri May 13, 2005 2:23 am
If not in a hurry i can but heading to oz for 2 weeks on monday. they arent hard to do except the inner c'vs can sometimes require a sizeable donging device! let me know what you get priced and p.m me if you havent sorted the install in the next 3 weeks.
quinny
