need help with electrics
Postby SIDE_FX » Sun May 08, 2005 7:08 pm
ok the car
1986 nz new gt corolla
turn head light switch round once ok parks come on click round again for full lights, no lights come on high beam lihght comes on push forward for highs nothin happens pull back to flash highs, highs come on,
things ive checked switch itself broght new one tried still has prob, relay in engine bay belive it works but when u pull back on lightr s lever with key on relay goes mental starts buzzin, relay under kick panel checked, fixing answer recive 6 pack if in aucks :D thats how $&#$% annoyin this prob is :P
SIDE_FX
Re: need help with electrics
Postby Lloyd » Sun May 08, 2005 7:13 pm
SIDE_FX wrote:no lights come on high beam lihght comes on push forward for highs nothin happens pull back to flash highs, highs come on,
Umm..... wtf are you meaning?
Checked all your fuses?
Postby UTERUS » Sun May 08, 2005 7:16 pm
Its because its fwd! :wink:
Its telling you to get rid of it and get a rwd fool.
Errmmm, bump
UTERUS
Postby Silent Knight » Sun May 08, 2005 7:37 pm
UTERUS wrote:Its because its fwd! :wink:
Errmmm, bump
Do you ever have ANYTHING useful to say or do you just like talking shit on a regular basis?
SIDE_FX...could you please explain in a little more detail and try using english what exactly the problem here is?
Silent Knight
Postby SIDE_FX » Sun May 08, 2005 8:19 pm
na uterus is my mate he wants me to gey a rwd,
ok the headlights dont come on but the high beam light does u know the one in the dash ? yeah i have checked the fuses in the fuse box nd in the kick panel but yeah no luck eh.
need help quick my miss's wont $&#$% in mums :P
SIDE_FX
Postby Alex B » Sun May 08, 2005 8:33 pm
possibly the headlight relay in one of the fuseboxes under the bonnet.
Postby SIDE_FX » Sun May 08, 2005 9:31 pm
na i can hear it ckicking when i try switch them on even behind the kick panel
SIDE_FX
Postby Alex B » Sun May 08, 2005 9:43 pm
um im prety sure just the parklight relay is in the kick panel
Postby fx gt » Sun May 08, 2005 9:52 pm
Errmmm, bump
Do you ever have ANYTHING useful to say or do you just like talking sh*t on a regular basis?
i thought it was funny:P
fx gt
Postby matt dunn » Sun May 08, 2005 10:24 pm
OK, Here's how the system works.
The Stalk on the end that you are turning turns on the relays for the park and main headlights.
These relays put power down tho the headlight bulbs.
the power goes through the bulbs back into the base of the switch assembly where there is some contacts that switch the earth on and off to control the lights.
The high beam light does not actually tell you when high beam is on, but actually when low beam is off. the fact that the HBeam light is on tells you that the stalk switch fuses and relays are ok.
Toyota's have problems at the bas of the column in the multi pin plug quite often, but it is also possible that the fault in in the contacts inside the base of the switch. ( basically at the other end of the stalk)
Does that make sense to you.
Matt
Postby SIDE_FX » Sun May 08, 2005 11:24 pm
yeah man perfect sense but as a bove i have brought a whole new stalk assembly and put it but it still does not work but i think u are also talking about the plug that this plugs into eh?
SIDE_FX
Postby matt dunn » Mon May 09, 2005 12:11 am
SIDE_FX wrote: but i think u are also talking about the plug that this plugs into eh?
yeah, check the pins in the plug, they can get dirty or quite often melt in the plug.
Postby SIDE_FX » Mon May 09, 2005 4:49 pm
i shall check on weds
SIDE_FX
Postby Rob » Tue May 10, 2005 8:52 pm
Could be the combination switch. had that on one of my coronas
1990 ST185H - project
1996 VS Acclaim wagon
Rob
