2LTR Rona wrote:plus & leads, what are the better products to look at. And what about suppliers are there sme I should just forget about looking at ?
All_Fours wrote:to continue on what Kinloud said, I believe st182/3 GT-R (3sge engine) extractors are a better design than st162 (maybe that's what you meant Kinloud?), and they will also bolt on. Should give a reasonable increase for very few $$ (pick-a-part)
bad20v wrote:Here's couple of pics showing my filter and cold airbox setup:
http://i2.photobucket.com/albums/y49/ba ... NTAKE2.bmp
http://i2.photobucket.com/albums/y49/ba ... NTAKE1.bmp
Hope this helps.
2LTR Rona wrote:All_Fours wrote:to continue on what Kinloud said, I believe st182/3 GT-R (3sge engine) extractors are a better design than st162 (maybe that's what you meant Kinloud?), and they will also bolt on. Should give a reasonable increase for very few $$ (pick-a-part)
hmmm very interestingcheers for that will have to look at that option somemore.
i would assume that if i went that route modifactions to the rest of the exhaust would have to take place as well
gmacrae wrote:what Al said - The worst money you could spend would be on platinum or especially iridium plugs. Get stock copper plugs, either denso or ngk, these will give you the best power, though they wont last as long, but who cares when you pay 3 or 4 bucks a plug
