catalic converter wiring...
Postby blackmk3 » Thu May 26, 2005 8:08 pm
the cats all rusted and bung on my car so uim gna take it out on the weekend, just wondering about the cat heat sensor...do i just cut it out snip the wires and leave them un connetced or snip them and join the wires...i know the ecus gotta b talking to it....just wondering how i wound go about it chhers!
Mk3 MA70 Supra
blackmk3
Postby fx gt » Thu May 26, 2005 8:16 pm
on mine the wires are cut of and left dangling near the hand brake switch
fx gt
Postby blackmk3 » Thu May 26, 2005 8:38 pm
yeah thats what i thaught a few of my mates kars theve taken them out and just left them dangling but i just thaught id confirm it and ask some people in the know...
Mk3 MA70 Supra
blackmk3
Postby Malcolm » Thu May 26, 2005 10:36 pm
normally the cat temp sensor just activates the warning light on the dashboard. Unplugging it will turn the light on, I think if you join them together it will turn off
Postby Ae92typeX » Thu May 26, 2005 11:03 pm
All_Fours wrote:normally the cat temp sensor just activates the warning light on the dashboard. Unplugging it will turn the light on, I think if you join them together it will turn off
Ive found the opposite to occur on afew cars ive done also, so it may depend on the sendor or how its wired up.
Ae92typeX
Postby blackmk3 » Sun May 29, 2005 10:56 am
ok cool chhers for that guys ill get stuck into it today
Mk3 MA70 Supra
blackmk3
Postby JRS » Sun May 29, 2005 5:48 pm
just cut the sensor mount off the cat and weld it into the replacement pipe. then bolt the sensor. and ex temp warning can be useful in a highly modified car. if you just want the light to got out then u can unplug it. if that doesn't put the light out you need to earth the wire (single wire) or solder the wires together (2 wire).
meh.....
JRS
Postby the fallen303 » Tue May 31, 2005 3:11 am
when i changed the exhaust on my ma70, i just unplugged the sensor, and left it at that. no warning lights on the dash, and car did not drop into limp mode or anything. to get to the plug, pull the drivers seat out and pull back the carpet, it's there next to the drive tunnel.
true house of JZ
Stay true to the origin
the fallen303
