100k Q's??
100k Q's??
Postby B ROWDY » Sat May 28, 2005 12:12 am
Hmmm, its fast approaching the Seralicious's 100, 000k birthday, can I get advice on what it will need to make her happy on this special occasion??
Its auto (shame) and has had regular servicing, does it need anything special? Also whats up when you put your foot on the brake and it feels like its bouncing as you slow done (pedal not car bouncing that is)
Cheers from your favourite blonde
XXX
B~ROWDY The Thread Whore Formerly Known As SERABABY
B ROWDY
Postby Lloyd » Sat May 28, 2005 12:17 am
100,000 you'll probably want to check plugs, cambelt done if you haven't yet, fuel filter, replace any fluids that need doing (gearbox etc). As for your pedal you'll probably want to get the rotors machined or replaced to fix that.
Postby B ROWDY » Sat May 28, 2005 12:18 am
Ah, you are wise my friend, thank you for not harrassing the simple one!
XXX
B ROWDY
Postby dazzag » Sat May 28, 2005 1:40 pm
you can @ least get 250,000kms if you keep the maintence. 100kms most important thing is the cambelt. get that done first priority.
as said above about your brake pedal. your brake rotors need machining(or replacing) but machining is good enough. you may also want to consider replacing the brake pads as they can wear unevenly with the discs causing a funny noise
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby B ROWDY » Sat May 28, 2005 2:10 pm
Cool, thanks guys! I have a feeling the cambelt aint cheap though, lol, its WOF is due in two weeks, guess Ill find out then how pies my brakes are!
B ROWDY
Postby Silent Knight » Sat May 28, 2005 2:15 pm
Cambelt is pretty cheap to buy just the belt from Repco. The expensive part is paying for labout for someone to install the cambelt if you can't do it yourself.
As for you disks...I've just been through the same thing in the Soarer. Brought brand new disks and pads and she's all fine now. I'd recommend rather than machining get new disks and then new pads to go with the disks. It's pointless getting new disks and then not new pads.
Also flush your brake lines after getting the brakes done.
Silent Knight
Postby Mr Revhead » Sat May 28, 2005 3:06 pm
not unusual for cambelt parts to be dearer aftermarket than genuine..
wont cost too much for the sera. $250 maybe?
certainly do the pads, fluid and discs, no point only doing half a job
Postby gtz666 » Sun May 29, 2005 12:02 am
With the pedal bouncing it could also be a ball joint on the lower arm thats stuffed. Have known to be wrong though :)
gtz666
Postby fangsport » Sun May 29, 2005 12:18 am
does the car have ABS?
i've been in a few freshly imported ABS equipped cars that had a pulsing in the brakes , and was fixed by putting fresh fluid in the system
fangsport
Postby B ROWDY » Mon May 30, 2005 9:37 pm
Mr Revhead wrote:not unusual for cambelt parts to be dearer aftermarket than genuine..
$250 for what exactly Big W??
B ROWDY
Postby B ROWDY » Mon May 30, 2005 9:39 pm
fangsport wrote:does the car have ABS?
Um, ABS? I have no idea, its an old car now, '90?
B ROWDY
Postby Alex B » Mon May 30, 2005 9:40 pm
if the wheels lock up when you press the breaks hard then you dont have abs. :D
Postby Mr Revhead » Mon May 30, 2005 9:43 pm
$250 for the whole job..... thats the cheapest id expect
Postby B ROWDY » Mon May 30, 2005 9:47 pm
Oh thats ok, I was being a bit blonde and thought the farkin belt was $250!!! My eyesy-balls nearly felled out my head! 8O
B ROWDY
Postby B ROWDY » Mon May 30, 2005 9:48 pm
pyro_sniper2002 wrote:if the wheels lock up when you press the breaks hard then you dont have abs. :D
Well, Im a chronic tail-gater and I dont know the difference, I always slam em on, shut my eyes and hope for the best, any other way to tell?
B ROWDY
Postby Bling » Mon May 30, 2005 9:54 pm
drive down a road (empty) at say ummmm 50-60 and slam on the brakes , then report back to us what happens :lol:
Postby Alex B » Mon May 30, 2005 9:56 pm
hahahahahha thats fully ausome shutting eyes while driving :lol: :lol: :lol:
Postby B ROWDY » Mon May 30, 2005 10:01 pm
Yeah, my technique needs to be refined a little! Can I do it on a hill? I live on a hill and I can go really fast!! lol!! and its way more fun going down hill with eyes closed! 8)
B ROWDY
Postby B ROWDY » Mon May 30, 2005 10:02 pm
BZG|Bling wrote:drive down a road (empty) at say ummmm 50-60 and slam on the brakes , then report back to us what happens :lol:
:?: Um will this kill me?
B ROWDY
Postby Alex B » Mon May 30, 2005 10:11 pm
no it will not kill you but if you dont have abs it wil hurt your tyres a lil
