Air conditioning not working on AE101
Postby Dirtbag » Tue May 31, 2005 6:00 pm
I have a feeling that this may have been covered before, but after a search I couldn't uncover anything definitive.
Righto,
Basically, I have a permanent heater, regardless of where I put the temperature knob, or if I have the ac/eco buttons depressed, or if I am circulating from outside, or inside. I hadn't realised it wasn't going as it was the first time I have used the cooling feature in ages, so it could have conked out at any time really.
Thanks for any help
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby Silent Knight » Tue May 31, 2005 6:36 pm
might need regassing?
or it could be clogged up...
I had the oposite in my supra whereas it couldn't blow hot air....it was just clogged up in the end.
Silent Knight
Postby matt dunn » Tue May 31, 2005 7:14 pm
The motor that moves the lever inside the heater unit from hot to cold will be not working.
Postby dazzag » Tue May 31, 2005 7:37 pm
is it permanent hot air or is it just normal temperature like its not cooling?
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby blackmk3 » Tue May 31, 2005 7:54 pm
mite b the heater tap in the engine bay not closing therfor hot water is constantly circulating round ur heater
Mk3 MA70 Supra
blackmk3
Postby matt dunn » Tue May 31, 2005 10:25 pm
blackmk3 wrote:mite b the heater tap in the engine bay not closing therfor hot water is constantly circulating round ur heater
Modern cars also have a flap inside to switch from hot to cold,
otherwise when the heater is on hot and you switch to cold you have to wait for the core to cool down before you get cold air.
In fact quite a lot of modern cars do not even have heater taps.
Postby Dirtbag » Tue May 31, 2005 11:09 pm
It seems to be heating it at all times, I was driving around the other day and it was chilly chilly outside, and the air coming in was really really warm, even with a/c and climate control on 21 or what ever ae101s go down 2
My profile!
Dirtbag
Postby dazzag » Wed Jun 01, 2005 11:30 pm
ok doesnt sound like a air con fault. it sounds like the flap that determines the air temperature mix is stuck on guideing all the air through the heater core. ae101s have cable type swiches from memory???? if its a cable type check the cable moves when you chnge it from hot to cold. if its electronic it could be either the motor that moves the flap or a faulty temperature selection switch
dazzag
Users browsing this forum: Bing [Bot] and 26 guests
