Wheel Shake
Wheel Shake
Postby zandrakweb » Tue May 31, 2005 10:46 pm
A very scary thing happened to my car last night that has made it not drivable, and it decided to happen when going 100 on the motorway, My steering wheel started to shake once i got to 100kph, at first i thought it was just the wheel balancing/alignment/new tread, etc. but then as i slowed down, the shake seemed to slow down aswell, but at the same strength. It got worse and worse in a matter of minutes untill the whole car was violently shaking, this was obviously after pulling off the motorway twice and checking my studs were tight.
I managed to make it to a gas staition, i jacked up the car took the wheel off and i found that my hub was actually loose, it could be wobbled a bit. What causes this? there just constantly seems to be things going wrong with this car, i cant keep up with it :(. could be worth dismantling for parts.
zandrakweb
Postby Quint » Tue May 31, 2005 11:20 pm
I'm guessing the bearings have callopsed, happened in my car, cost a pretty penny to find a new hub.
Quint
Postby Mr Revhead » Tue May 31, 2005 11:44 pm
could be the hub nut just came loose, big problem on WRXs
try tightening it, and then going straight to a mech, if you cant tighten it, call a mobile mechanic
Postby zandrakweb » Wed Jun 01, 2005 1:44 am
sweet, ill give it a go... if anyones keen on parts.. give us a yell :lol:
zandrakweb
Postby KinLoud » Wed Jun 01, 2005 8:38 am
I have a rear hub off an AE101 for sale. Bearings all good.
$60 plus freight.
Ken
Hamilton
021 408 863
Postby dazzag » Wed Jun 01, 2005 10:59 pm
Strange.... check the cv joint to. it supports the hub from behind. the hub shouldnt just have come loose all the sudden. either the cv shaft bolt is loose or the bearing must have collapsed. was there any strange noises coming from that wheel weeks before?
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby dazzag » Wed Jun 01, 2005 11:00 pm
KinLoud wrote:I have a rear hub off an AE101 for sale. Bearings all good.
$60 plus freight.
wont be the rear if the steering wheel was shaking
dazzag
Postby nz_baddass » Tue Jun 14, 2005 7:37 pm
ae101 ae100 and ae111 all the same hubs, look aroun for a good 2nd hand one, v easy to replace if you got the tools
nz_baddass
Users browsing this forum: Bing [Bot] and 17 guests
