Urethane - where to get it?
Postby MrOizo » Thu Jun 02, 2005 8:23 pm
I was wondering where one can get blocks of urtthane and have it machined into desired shapes...
is this expensive to do also?
what i wanna do is in the link and pics below.
The're engine mounts and these are made of something caled Delrin.
I was thinking that with the right dimensions i could have some made up and not have to fork out millions and wait years for them to arrive..
http://www.aapmotorsports.com/catalog/p ... cts_id=923
What you think is another idea to do... other than going stock of course :)
MrOizo
Toyspeed Legend
Postby ee904age » Thu Jun 02, 2005 8:41 pm
I can get it for you.
Or if you want to be flash, you can get sticks of Nolathane to machine up.
If your interested in urethane, suss out the sizes you will need and Ill get some prices for ya.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
mount
Postby JasonZE » Thu Jun 02, 2005 10:53 pm
That looks more like a type of nylon bush,
Here in Christchurch I get stuff like that from a firm called engineering plastics they have all types of plastic nylon etc etc for machining purposes so look in your yellow pages for something similar or give them a ring.
I have seen a website where guy fill the original engine mounts with liquid urethane to make them stronger and stiff.
JasonZE
Real Life Mechanic
Postby MrOizo » Fri Jun 03, 2005 8:28 am
Wicked, Cheers. Not too sure on the sizes but will let you know.
I know the site, well one where they do that. Was a AW11's 20v mounts.
Just had a look and cant find the freaking thing! thought it was this site: http://www.padandwheels.com/mr2 but it aint... well might be just cant find it.
Wicked found it!
http://opc.mr2oc.com/online_parts_catal ... mounts.asp
my mounts dont work like these. instead of these where the mount's bolt passes through the mount tangential, mine are basically a long bolt through the mount itself. i cant really explain but trying to find pics to explain.
Not like these:
But rather like these:
hope i make some sense for this early in the morning :)
MrOizo
Toyspeed Legend
Postby THA SHZ » Fri Jun 03, 2005 9:23 am
try talking to autolign as they can make anything out of nolathane , they redid my enginemounts and a few other bits and pieces . 8)
THA SHZ
Postby MrOizo » Fri Sep 16, 2005 10:42 pm
Bumpity Bump Bump...
Any more suggestions people?
cheers..
MrOizo
Toyspeed Legend
Postby Si » Sun Sep 18, 2005 10:53 pm
Have a chat to BNT if you hadnt already,
they should be able to help,
from memory someone also makes solid mounts with rubber washes ateach end or something overly crazy
Current: , '96 SubaruImpreza
Si
Postby Si » Sun Sep 18, 2005 11:22 pm
those are the suckers:)
Si
Postby ChaosAD » Mon Jun 18, 2007 8:50 pm
I want to do the same thing http://www.geocities.com/ae82power/umounts.html
Where can I get the urethane from at a reasonable price?http://www.mr2supercharger.com/engmounts.html
ChaosAD
Postby neo » Mon Jun 18, 2007 10:37 pm
I got mine done by Thorndon Rubber down here in Welly. You'd need to talk to the boss about it.
I also used new mounts and got the gaps filled, thus they didnt have any problems with greese and oil
neo
Postby toyae86 » Tue Jun 19, 2007 10:20 am
ludowici plastic's engineering plastics mulford plastics
i got some nolathane 75mm rod from ludo's not that long ago
toyae86
Postby malc » Tue Jun 19, 2007 12:32 pm
THA SHZ wrote:try talking to autolign as they can make anything out of nolathane , they redid my enginemounts and a few other bits and pieces . 8)
I second that,
I went for a tour of autolign, they do a lot of custom work with nolathane.
They showed us some engine mounts for a fleet of busses they were making.
Plenty of experience in that place.
malc
