4k Overheating
4k Overheating
Postby 1goodidea » Thu Jun 02, 2005 9:00 pm
I've had this problem with both my starlets with both of their k-series motors, how do i stop the motor from over-heating if im stoped with the car running for a few minutes or at major traffic jams.
Radiator is in reasonbile condition, it's a stardard kp60 item with a few broken fins
any ideas, anyone else have this problem?
1goodidea
Postby pervert » Thu Jun 02, 2005 9:35 pm
I've had a few K's, and never had any real overheating issues.
Is the radiator fan running at all?
Overheating in traffic sounds like it might not be.
pervert
Postby Ae92typeX » Thu Jun 02, 2005 9:51 pm
things like correct fuel mixture and timeing also can contribute heaps to heating problems, although the radiator would be my first port of call.
Have you ever backflushed it?, even if it looks ok it could be clogged. Also as above, check the fan is operating too
Ae92typeX
Postby dazzag » Thu Jun 02, 2005 10:36 pm
also may want to check the thermostat isnt jammed
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
check
Postby andyztouring » Thu Jun 02, 2005 11:31 pm
check that the fins (or propellor) hav`nt come off on the waterpump,this happened to my parent`s KE70,overheated the engine.
andyztouring
Postby TygerTung » Thu Jun 02, 2005 11:39 pm
Yeah, is your radiator fan going?
I've NEVER had any problems with overheating in any of my K motor's, they usually run pretty cool actually.
I don't even have a fan on mine at the moment, and it only gets hot if you are sitting in one spot for like 5 or more minutes.
TygerTung
Postby Dell'Orto » Thu Jun 02, 2005 11:50 pm
Mine only heats up in stop start traffic, but the radiator is pretty poked. Ordinarily its fine.
Hows the radiator cap too?
Postby Rob » Fri Jun 03, 2005 12:20 am
My 4K overheated when I tried to be a cheap arse and went from twin carb to single carb. (had big cam though)
Make sure yo got no vacuum leaks or manifold leaks
Other than that it should be sweet. Trust me you can't kill a "K" series engine with running it dry of water and oil at the same time!!!!!!!!!
Also check gaerbox level if you still worried. When my gt4 gearbox blew my engine over heated :wink:
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby 1goodidea » Fri Jun 03, 2005 7:44 am
k thanks guys, fan works, cap sweet, fushed it out once i'll give that another go this weekened
1goodidea
Postby AE85coupe » Fri Jun 03, 2005 8:39 am
could be a blown head gasket....
AE85 Trueno *For sale*
Details of car here
AE85coupe
