gas volume in a shock asorber
Postby Mr Revhead » Fri Jun 10, 2005 12:47 pm
anyone have any idea how much gas is "typically" in a shock asorber?
i can find the pressure, now i need the volume....
sending shocks overseas on NZPOST is a drama..... :evil:
Postby RomanV » Fri Jun 10, 2005 1:18 pm
Couldnt you just measure the length and circumference of it, to get a rough (good enough?) idea?
Postby Mr Revhead » Fri Jun 10, 2005 1:35 pm
ah... no.
shocks arnt totally gasfilled, they are oil filled.
the gas is there to keep it under pressure and avoid foaming.
so only a small section is filled with gas
Postby bad20v » Fri Jun 10, 2005 1:37 pm
wat vehicle are they from?
Thank-You.
bad20v
Postby Mr Revhead » Fri Jun 10, 2005 1:39 pm
uzs131 airbag struts.
rears.
Postby atmosports » Sat Jun 11, 2005 9:21 pm
Generally I've found most competition type shock units, either with or without remote cannisters have between 20-100mm of their length as gas with a 45-50mm piston so you do the maths on that. Road shocks generally are smaller diameter etc so would probably have a lil less volume, but it's kinda hard to measure as most factory shocks are sealed & you have to cut them to get them open & as soon as you cut through the gas disappears before you egt a chance to do any sort of measurement on it.
atmosports
Postby Mr Revhead » Sat Jun 11, 2005 9:39 pm
yeah i figured it would be a tiny amount.
seems the pressure limit for shocks on airplanes is 280 bar 8O
and a volume of 1.6 litres
you multiply the volume in litres by the bar and if its over 80 its no go
seeing as the highest pressure i could find on google was 360ish PSI... i cant see many shocks not being exempt
bloody beuracrats :evil:
Postby Adamal » Sat Jun 11, 2005 9:49 pm
Just fill it out "Less than 1.5l" :D
Postby Mr Revhead » Sun Jun 12, 2005 12:26 pm
i wrote a big-worded letter quoting several sources so hopefully that will do.
they origanally wanted a statement form the manufactorer stating the info.
oh what fun it would be getting that out of japan 8O
