4A-GE Engine drop replacement of 4A-FE?
Postby Shinda » Fri Jun 10, 2005 10:12 pm
I just got a 1996 AE111 Levin XZ the one with the FE engine in it. I was wondering weither to run the 20v head and new engine management system, or if maybe all the engine mount points are the same and drop the whole engine in. weither it's can be a straight swap.
Shinda
Postby Alex B » Fri Jun 10, 2005 10:36 pm
The answer unfortunatly for me also is no the head does not fit. Just get a wrecked bz-g box, loom engine and ecu
Postby Shinda » Fri Jun 10, 2005 10:37 pm
so what your saying is that the engine mount point are the same and the engine should just drop in?
Shinda
Postby Alex B » Fri Jun 10, 2005 10:39 pm
im prety sure they both ae111's?
Postby Shinda » Fri Jun 10, 2005 10:48 pm
yip AE111, how much a black top engine worth?
Shinda
Postby Alex B » Fri Jun 10, 2005 10:52 pm
Postby Shinda » Fri Jun 10, 2005 10:53 pm
thanks bro
I might have to wait a while no cash and wan't to get some rims first
Shinda
Postby quinny » Sun Jun 12, 2005 6:24 am
you will need plenty! as i found out
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby Shinda » Sun Jun 12, 2005 2:33 pm
did you do that drop into your ae101?
AE111 96 Levin ""4A-FE"" Need rims first though..... :(
Shinda
Postby Alex B » Sun Jun 12, 2005 7:24 pm
quinny wrote:you will need plenty! as i found out
what do you call plenty??
You would need loom, ecu, box (maybe) engine maybe brakes. And certs of corse so your probly looking at 2k max.
Postby matt dunn » Sun Jun 12, 2005 7:52 pm
Shinda wrote:yip AE111, how much a black top engine worth?
You could also go silvertop as they are thye same mounts too,
and will be a lot cheaper,
Postby quinny » Mon Jun 13, 2005 9:35 am
$4500 my conversion cost doing everything myself except the wiring. I Didnt need a cert cos i used the brakes from the blacktop donor. Motor and 6 sp are all noted on the wof sheet. 2 grand will at best cover hardware and nothing else. I could have put a silvertop in my Ae101 but I have a hatred towards air flow meters and once you go black, you will never look back
quinny
