The wild levin click, been over all basis
Postby crazor » Sun Jun 12, 2005 5:11 pm
I know that there are many topics about the clicking and so that you get with the levins, but ive been through all areas and i keep getting no luck and its rather annoying now.
Symtoms
Clicking coming mostly from the front right wheel area, the clicking is total irregular, its most prevalent wen accelerating and decelerating from the 0-30km braket.
The cv's have been checked and there fine , the wheel bearing is brand new so cant be that, is this a problem that comes when the bushes in the superstrut suspension need to be replaced?
Im sure someone must of had a simalar problem, please help.
Also who in auckland is good to go to, to get suspension checked out , i have been told good things about pedders .
Regards
crazor
Postby TrouserFxGt » Sun Jun 12, 2005 7:29 pm
I had a similar sound in my car. I thought a cv was on the way out and after about 2 hours of investigation I found the engine mount loose.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby matt dunn » Sun Jun 12, 2005 7:47 pm
Also check the strur bar where it mounts to the firewall.
Although that's more when cornering.
Our AE111 was clicking and we tracked it down to that. They have to be real tight.
Matt
Postby crazor » Sun Jun 12, 2005 7:55 pm
loose engine mount :S
The strut bar is fine just checked that , wouldnt know how to check the engine mount :S
If anything i get it going in a straight line more often then turning
crazor
Postby z|gen » Sun Jun 12, 2005 8:01 pm
possibly could also be the sway bar bushes, they make a sort of clicking/knocking sound when they need replacing..
AE91 SUPERCHARGED COROLLA
z|gen
Postby Rob » Sun Jun 12, 2005 8:34 pm
Park your car with the hand brake on and out of gear. See if the wheel will move backwards and forwards by turning the wheel. If it moves then its bushes of some kind
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby aesc » Sun Jun 12, 2005 9:21 pm
Ok im glad you posted this topic cos I have the same symptoms except from the left front wheel. My car has been into the mechs about 2-3 times and they dont know what it is...
One thing I noticed is that if your decelerating the knock is there, but once you push the clutch in it disappears. Does yours do this? Ive noticed that the noise seems to be coming directly from the wheel area too
So you have had the CVs checked, and wheel bearings done.
Heres the list of things which mine is had in the front suspension in the last year or so:
New front shocks, new S/S lower arms, new sway bar links, new sway bar bushes, new LF ball joint (connecting strut to hub). So I can confidently say its none of them.
The only thing I can think of is maybe a wheel stud, or possibly the trailing arm (or whatever its called :lol: ). Seem to be the only things I haven't replaced
Its more of an annoying sound than anything but damn i want it gone!
EX AE101 owner
2013 Ford Focus ST
aesc
Postby crazor » Sun Jun 12, 2005 9:58 pm
The cars and auto so no clutch lol
The car has also had the calipers and brake pads replaced on the front , it was doing it before this and still does it after .
It does get worse when i drive my car on a reg basis, i know its not a engine prob.
Im going to get the most through suspension check possible done, they guys who do this know more than most about levins and there ss goodness so im hoping it can be pin pointed.
crazor
Postby Mr Revhead » Mon Jun 13, 2005 12:33 am
i have a similar noise.
on mine its the metal locking cap over the hub nut.....
Postby crazor » Mon Jun 13, 2005 8:25 am
Theres something i didt think off, ill check that tonight.
Mr-revhead u have a pm
crazor
Postby Mr Revhead » Mon Jun 13, 2005 9:15 am
whats my sig say? :wink:
Re: The wild levin click, been over all basis
Postby THA SHZ » Mon Jun 13, 2005 10:24 am
Regards
pedders are no longer exisistant so ur best bet wood be to try sas in manukau as they are pretty on to it dudes and all they do is work on suspension alkl day long 8)
THA SHZ
clicking
Postby Fandango » Mon Jun 13, 2005 3:47 pm
Mine has exactly the same problem too. Ive replaced 3 out of 4 cv's and got fed up so I just left it how it is.
I would REALY like to know what it is.
Fandango
Postby 1598cc » Mon Jun 13, 2005 3:59 pm
inner cv's ?
1598cc
Postby aesc » Mon Jun 13, 2005 4:21 pm
crazor wrote:The cars and auto so no clutch lol
Ok what about when you put it into N then? :P
1598cc wrote:inner cv's ?
Nope not likely be be the inners, like Fandango said he has replaced 3 out of 4 off his CVs on his GTZ. Ive been told that inner CVs hardly ever fail so doubt its that
Might be worth checking the metal locking cap over the hub nut like Revhead suggested.
Warwick, is it a matter of replacing the part to stop the knocking, or adjusting it in some way?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Mon Jun 13, 2005 4:25 pm
no idea! once i found out what it was, i stoped caring :lol:
im sure it wouldnt take much to sort it
Postby GTCRSHR » Mon Jun 13, 2005 5:46 pm
its not the plastic splash sheild is it ?
Nothing to see here ...
GTCRSHR
Postby aesc » Mon Jun 13, 2005 6:22 pm
Mr Revhead wrote:no idea! once i found out what it was, i stoped caring :lol:
Haha lazy....
GTCRSHR wrote:its not the plastic splash sheild is it ?
Na not on mine, sounds too 'heavy' to be that, sounds like metal hitting metal
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Mon Jun 13, 2005 6:30 pm
nah not lazy, just once i knew it wasnt a problem it didnt matter 8)
Postby crazor » Mon Jun 13, 2005 6:35 pm
Im starting to get to the i dont care stage now, i cant feel it through the pedals so it cant be that bad ----- famous last words:S
crazor
