cat converter light????
Postby RickGT » Wed Jun 15, 2005 11:52 pm
ive recently had a new exhaust fitted and now the cat light is constantly on, how do i fix this, does it do anything to the performance?
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby Caveman » Wed Jun 15, 2005 11:55 pm
Cat light?
Its probably the O2 sensor which is suppose to plug into the cat.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby RickGT » Thu Jun 16, 2005 12:01 am
yea there was a wire goin into it b4, thought its a temp sensor, oxy sensor is off manifold
EP91 Glanza V
RickGT
Postby AceSniper » Thu Jun 16, 2005 12:06 am
yea its a temp sensor, most places spot weld the end of the sensor to the exhust pipe... I think it needs to be earthed
AceSniper
Postby RickGT » Thu Jun 16, 2005 12:20 am
sweet thanks
EP91 Glanza V
RickGT
Postby Bling » Thu Jun 16, 2005 1:19 am
take the bulb out :lol:
Postby sergei » Thu Jun 16, 2005 9:22 am
if it is AE 101 , jus pull the carpet on the driver side just below the stereo, you will find wire with socket going thru body to outside, disconnect that...
Postby Adamal » Thu Jun 16, 2005 9:53 am
Judging by his sig, which says "α ε 8 2 Τ о у о т а Со я о І І а ƒ х - Ġ т Τ ω ϊ η с а м ", along with the pic of an FX-GT and a 16v 4AGE, as well as a 16v 4AGE as his avatar, I don't think he has an AE101. Just a hunch :)
Postby RickGT » Thu Jun 16, 2005 1:48 pm
is the wire found in the same place as the ae101's???
EP91 Glanza V
RickGT
Postby soopachargen » Thu Jun 16, 2005 1:59 pm
when i had my exhaust done on my old ae82 they just cut the sensor off and tucked the wire over the exhaust. My idle pulsed a bit for about a week but then it was sweet. a couple of months later when i had the carpet out i just unplugged the cat wire and i now use it as a weapon against my little brother.
i only ever had the cat light on when it was clogged up before being replaced.
When in doubt, down and out.
soopachargen
Postby RickGT » Thu Jun 16, 2005 4:44 pm
yea theve obviously just choped it righ off, where bouts do i find this under the carpet???
EP91 Glanza V
RickGT
Postby fatgtr » Thu Jun 16, 2005 5:09 pm
just ground the wire to the frame of the car. :D
James
gotta love the punk music
fatgtr
Postby RickGT » Thu Jun 16, 2005 5:31 pm
yea but i have to find it first
EP91 Glanza V
RickGT
Postby RickGT » Wed Jun 22, 2005 10:51 am
yea so i had a look under the carpet an couldnt find anything! anybody got any clues to where it is?
EP91 Glanza V
RickGT
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
