3 point strut brace? extra rigidity?
Postby ants_ae92 » Mon Jun 13, 2005 8:47 am
I saw a picture of an aftermarket strut brace on an ae111 levin that got my attention. It had three points of attachment. The standard ae111 strut brace mounting point on the firewall as well as a bar joining both strut towers.
Most aftermarket ones go strut tower to strut tower.
My ae92 came with an aftermarket strut brace from tower to tower. After seeing the photo of the ae111, I decided to make my own. I brought a standard ae92 brace and Im using that as well as the aftermarket brace.
It feels a bit stiffer up front, less lateral body roll, But is it theoretically any better to have the extra brace?
What do you guys think?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby TRDWGN » Mon Jun 13, 2005 4:31 pm
Triangle is the strongest shape, there's the benefit right there!! I believe the factory set up is better than simple strut to strut so incorporating both has to be the best idea :idea:
TRDWGN
Postby Mr Revhead » Mon Jun 13, 2005 4:37 pm
strut to strut stops movement relative to each other but not the firewall.
firewall to strut stops movement relative to firewall but still allows movemenst relative to each strut top.
both together ties it up nicely 8)
so each on does something, but both tegether are best
Postby bad20v » Mon Jun 13, 2005 4:37 pm
TRDWGN wrote:Triangle is the strongest shape, there's the benefit right there!! I believe the factory set up is better than simple strut to strut so incorporating both has to be the best idea :idea:
Right on the money there, go with the triangle.
Thank-You.
bad20v
Postby jasestu » Mon Jun 13, 2005 6:40 pm
Three (four?) point goodness on an Altezza:
I say four because it has a support for the master cylinder as well.
More detail in a thread at Altezza Club
jasestu
Postby Malcolm » Mon Jun 13, 2005 6:50 pm
hmmm, should've made the end plates higher so that the cross brace was straight and not bent, either that or used a thicker (taller) bar to compensate for the bends at either end, because those bends, particularly the sharper one on the driver's side, will bend more under load than you would think. It's still a good design, I just think it looks like they were attempting to make an "ultimate stiffness" brace, and could've done better :) Also the way that triangle has different angles on either side, coupled with the sharper bend on the driver's side, means the driver's side tower will have slightly more flex than the passenger side :)
Don't mind me, I'm just being pedantic
Postby 10k 20v » Mon Jun 13, 2005 9:26 pm
pics of my trd strut bar. Made a noticible diference over the stock bar for sure!!!
10k 20v
Postby Adamal » Mon Jun 13, 2005 9:39 pm
Strut braces are the bizniz. :D
Postby CozmoNz » Mon Jun 13, 2005 10:06 pm
why not head down to a local engineering shop, and get a peice of metal welded between the two points on the factory item?
oh, and have u an ae101 with a blacktop?
Rayne For President!
CozmoNz
Postby Malcolm » Mon Jun 13, 2005 11:12 pm
that trd one is awesome, would be stiff as hell!
Postby AceSniper » Tue Jun 14, 2005 1:57 am
cozmo... he sure does... he also knows a $&#$% load more than you ;)
mayaswell add to the line :D
AceSniper
Postby Mr Revhead » Tue Jun 14, 2005 10:59 am
that looks interesting, whats the big alloy thing after the AFM :?:
Postby TRDWGN » Tue Jun 14, 2005 11:01 am
ARC intake Chamber, supposedly adds mid range torque
TRDWGN
Postby Leon » Tue Jun 14, 2005 12:00 pm
Heh, I just put in a big eff off rollcage. Now that's some serious torsional rigidity.
Postby ants_ae92 » Tue Jun 14, 2005 12:26 pm
Thanks mr revhead, you explained both have their advantages.
Well I know have both, but they are just layered on top of each other.
Any benefits of welding them together?
And can I post pics straight on here, or does someone need to host them? Then i can post pics of my setup?
ants_ae92
Postby Malcolm » Tue Jun 14, 2005 12:53 pm
not really any point welding them together, layered should be fine provided the studs that hold them onto the strut top are not unduly stressed by having too thicker plates bolted to them
Postby CozmoNz » Tue Jun 14, 2005 1:46 pm
AceSniper wrote:cozmo... he sure does... he also knows a $&#$% load more than you ;)
calm the pms down eh?
CozmoNz
Postby 10k 20v » Tue Jun 14, 2005 7:47 pm
when fitted i noticed the doors would creek as much when going up and down driveways with one of the rear wheels off the ground :D
10k 20v
Postby AceSniper » Thu Jun 16, 2005 1:52 pm
|| ants_ae92 ||
AceSniper
Postby Leon » Thu Jun 16, 2005 2:58 pm
Heh heh heh
Users browsing this forum: Bing [Bot] and 25 guests
