Wheel bearings replacement
Postby Silvergun » Mon Jun 27, 2005 1:22 pm
How easy is it to replace wheel bearings?
i read somewhere that you need a special tool to do it, is that true?
pretty sure i got a buggered front bearing.
I have some but not extensive mechanical ability.
AE92 4age Redtop
Silvergun
Postby Ae92typeX » Tue Jun 28, 2005 12:59 am
depends on the car, some have pressed in beerings, others dont. You can do both at home with a selection of tools, but unless you are pretty confident then I would take a pressed in one to a specalist as they can be a bastard to get out and put in.
Ae92typeX
Postby Silvergun » Tue Jun 28, 2005 9:57 am
Ae92typeX wrote:depends on the car, some have pressed in beerings, others dont. .
its an ae92 fxgt. do thses usually have pressed in bearings?
AE92 4age Redtop
Silvergun
Postby THA SHZ » Tue Jun 28, 2005 10:36 am
yes 8)
THA SHZ
Postby 88AE92 » Mon Sep 12, 2005 4:09 pm
to bring this out of the morgue,
I have to do the bearing in a 92 MR2...
do these have pressed bearings or not?
I tried getting it pressed out but the guy managed to break the bearing carrier!!!
I got a new one, but its off a turbo so the hub center is different for the larger axle.
The bearings are the same however (i have checked at toyota)
I am guessing the way to do it is,
Press the hub center out of the bearing, then press out the bearing?
Any help will be much appreciated.
Andrew
88AE92
Postby beeker » Mon Sep 12, 2005 6:26 pm
I have no idea what i'm doing, and managed to change the fronts on my AE86 with careful use of a old screw driver and a hammer !
Used the old outter bearing shell to help press the new shell back in without damage to it.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Ae92typeX » Mon Sep 12, 2005 6:59 pm
beeker wrote:...Used the old outter bearing shell to help press the new shell back in without damage to it.
or you can use a big socket (depending how big your set goes)
Ae92typeX
