What does the selector fork look like?
Postby True ah no » Thu Jun 23, 2005 10:18 pm
Where abouts is it located on the gearbox?
True ah no
Postby Malcolm » Thu Jun 23, 2005 10:20 pm
the main differences AFAIK is the wiring loom is a bit different, and the selector fork on the gearbox is different. Both of these can be swapped quite easily for ones from FWD 4ages
Postby True ah no » Thu Jun 23, 2005 10:41 pm
what type of 4age would a 84 mr2 have? red or blue top?
True ah no
mr2
Postby JasonZE » Thu Jun 23, 2005 10:48 pm
blue
JasonZE
Real Life Mechanic
Postby True ah no » Sun Jun 26, 2005 4:19 pm
Where is the selector fork located and whats involved in getting it off?
True ah no
Postby NZ_AE86 » Sun Jun 26, 2005 8:58 pm
There will be three inside the gearbox. You will have to diassemble the gearbox to get them though!
NZ_AE86
Postby True ah no » Mon Jun 27, 2005 2:21 pm
Is it hard to do?
True ah no
Postby matt dunn » Mon Jun 27, 2005 8:10 pm
True ah no wrote:Is it hard to do?
If you have to ask a question like that then it's probably best you not attempt to pull apart a FWD box.
Postby True ah no » Tue Jun 28, 2005 12:30 pm
quote "If you have to ask a question like that then it's probably best you not attempt to pull apart a FWD box."
Well how am I meant to know if I havent done it before on this particular box, not all box's are the same. And theres ony one way to find out and thats by doing it isnt it! Ive worked on rwd box's before, just wasnt sure on the positiong of the folks and what parts will have to be removed in order to get to them on this particular box
True ah no
Postby vvega » Tue Jun 28, 2005 12:37 pm
just do it
worse cause you have to pay someone to put it back togethier
lern the hard way
:D
v
vvega
Postby 10k 20v » Tue Jun 28, 2005 9:22 pm
if you've had a rwd box apart you shoud have no problems with a fwd. once you have it apart its easy to see how it works.
10k 20v
Postby matt dunn » Tue Jun 28, 2005 10:40 pm
True ah no wrote:What does a selector fork look like?
True ah no wrote:Where is the selector fork located and whats involved in getting it off?
True ah no wrote: And theres ony one way to find out and thats by doing it isnt it! Ive worked on rwd box's before,
Sorry but with questions like the first two you made it sound like you had no idea if the selector fork was inside the gearbox or not and that you have never had a box apart.
Matt
