AE101 ECU issues
AE101 ECU issues
Postby AceSniper » Wed Jun 29, 2005 4:54 pm
I Just found a jap site on the net showing how to replace the two cap's that iv had stuff out and seen stuff out in other ecu's (leak) so just thought Id post it... incase you want to check or have weird issues with your ecu...
http://babelfish.altavista.com/babelfis ... le_ecu.htm
AceSniper
Postby 85AW20v » Wed Jun 29, 2005 11:09 pm
No wonder the site name is Babelfish........ If you can decipher all that you're doing pretty well :
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Wed Jun 29, 2005 11:17 pm
i read that
now my head hurts :x
but good info nonetheless.....
Postby Alex B » Wed Jun 29, 2005 11:30 pm
is this common in 101's as my friends marino died last year and went it to fail safe caused by condenser or something?
Postby Mr Revhead » Wed Jun 29, 2005 11:38 pm
its common enough. wont happen to all of them. but happens to enough that any auto sparky should have an idea of it
Postby AceSniper » Thu Jun 30, 2005 2:10 am
out of 4 ecu's iv opend two had the issue, and they were both pre 93 even tho both ecu versions have them in the same place on the board, cost about 10cent each at dick smith :P
when it happend to me the fueling was all over the place with foot to the floor it just made emough power to move and not stall, sometimes had to put clutch in an bring up the revs... was real werid also it wouldnt show any ecu faults just random blinks that ment nothing
AceSniper
Postby RedMist » Thu Jun 30, 2005 7:44 am
By the way, it is the condenser which the condenser and the right which problem have the left purchase this time anew. Don't you think?
Yep.... ummm ... what was the question again?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby bad20v » Thu Jun 30, 2005 11:25 am
My ae101 did the same thing. I got a guy in Papakura, who fixes amps and car stereo's, to have a look at it. He fixed it for $50, which is alot cheaper than some of the ripoff artist auto electricians up here in Auckland who charge up to $350 for a replacement computer!!!
Thank-You.
bad20v
Postby 92GTApex » Thu Jun 30, 2005 1:44 pm
Better than over 2 grand for a genuine one...
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
