All_Fours wrote:Anyway, assuming you've been confused and want to swap a 3sgte + 4wd gear from a st205 or st215, they will require a bit of wiring, but other than that it should be pretty straight forward if you get all the associated sensors an such.
The brakes, if you're talking st205 ones, bolt on at the back, the front however needs the disks machined down about 10-15mm (diameter), and a few other little bits, but it's mostly pretty simple.
