caldena rear lsd ??
caldena rear lsd ??
Postby vvega » Sat Jul 16, 2005 12:11 am
do caldena's have rear lsd's and if so what are they torsen or plate
i only ask as i saw this on trademe that coiuld be of interest to our caldena nutters
http://www.trademe.co.nz/Trade-Me-Motor ... 318136.htm
vvega
Postby fivebob » Sat Jul 16, 2005 1:09 am
Caldina rear ends are indeed LSD, but I don't know what type they are. Though this auction seems to imply that they are clutch pack.
One thing though is that the manual and auto models are different and require the stubs to suit the model from which they came, and thus probably have different splines. I don't know which one the quoted 41301-48020 part # is from as the online EPC no longer works.
Postby NZ_AE86 » Sat Jul 16, 2005 9:41 am
That is not a clutch pack LSD. Look close and you can see the gears inside it.
But I don't konw what Caldina rear ends have?
NZ_AE86
Postby vvega » Sat Jul 16, 2005 10:14 am
just looking though the hole in the side that almost has a helical trademark
interesting though i was under the impression that they were open :S
with the auto and manuel been different do you think that perhaps one of them could be in fact open ??
or even maybe a viscous rathier than a torsen ??
v
vvega
Postby fivebob » Sat Jul 16, 2005 10:24 am
NZ_AE86 wrote:That is not a clutch pack LSD. Look close and you can see the gears inside it.
That's just the spider gears, doesn't mean it couldn't have a clutch pack as well
Here is a pic of a TRD LSD to show what I mean
Postby fivebob » Sat Jul 16, 2005 10:31 am
vvega wrote:just looking though the hole in the side that almost has a helical trademark
I think that's just the spider gears you're looking at, see attached parts diagram. As to whether or not it's a clutch pack diff, as the diagram doesn't show any clutch plates as parts I would think in unlikely.
No, both are LSD, I can't say why they are different though.
Postby vvega » Sat Jul 16, 2005 11:20 am
this side is a helical.....................................................this side is a clutch
for those that didnt know
just somrthing i wanted to knwo fivebob :D
v
vvega
Postby NZ_AE86 » Sat Jul 16, 2005 2:23 pm
I am quite aware that an LSD will still have spider gears! But if you look at the pic on trademe the gear you can see through the hole looks like a helical cut gear which spider gears are not. :?
NZ_AE86
Postby fivebob » Sat Jul 16, 2005 7:28 pm
NZ_AE86 wrote:I am quite aware that an LSD will still have spider gears! But if you look at the pic on trademe the gear you can see through the hole looks like a helical cut gear which spider gears are not. :?
But look at the parts diagram, what you see in the pic are spider gears, well at least that's where the spider gears should be if it's a Caldina LSD. The Caldina diff isn't helical(Torsen), as the worm/helical gears in a Torsen style diff replace the spider gears. Much more likely is that it's a viscous coupling.
Postby sergei » Sat Jul 16, 2005 8:20 pm
Speaking of diffs, what type is the rear diff out of a ST165 (pre-facelift)
and a ST205 (wich I have now in my 165)? I thought that Caldina should have ST205 diff at the back...
Postby vvega » Sat Jul 16, 2005 10:28 pm
265 is open
185 is torsen as is 205
vvega
Postby NZ_AE86 » Sun Jul 17, 2005 12:43 pm
Yes But we are not talking about your diagram! We are looking a diff on trade me and that is the diff I am refering to. I can see clearly on your diagram that there are spider gears there! :)
NZ_AE86
Postby vvega » Sun Jul 17, 2005 1:19 pm
it also dosent show any clutch plates
it also dosent have a second lock ring for a vicous setup
so imo of epc interpretation that is a open diff
though in saying that they also have a habbit of useing generised pictures and when it comes tim to look up the parts you discover that they are not what they look like
just to add more confusion
v
vvega
Postby Mr Revhead » Sun Jul 17, 2005 2:37 pm
that part number is listed for the stated vehicles from about 98 onwards, and the st246 caldina, not the 215.
the pic shown above from the EPC does look like an open one to me.
you cant always tell a viscous from a helical on the EPC, but my guess is its a helical type. viscous diffs are sealed units afaik.
if any one is looking at that pic on the epc, hit the "next" button, and youll get some like this:
Postby fivebob » Sun Jul 17, 2005 3:08 pm
Thanks for clearing that up Warwick. According to Toyotas webpage the diff is Torsen.
It also appears that the diagram I posted is probably for an open diff :oops: seems that the ST215W autos were indeed an open diff, only the manuals were LSD. Strange as the auto car I dissambled appeared to have a LSD and apart from the mag wheels had no modifications. Must go back and check to see if it really is LSD or is stuffed from the side impact it received in the crash :evil:
BTW only ST246 GTFOUR-N models are LSD, mental note to self, only buy an N model
Postby vvega » Sun Jul 17, 2005 4:14 pm
great stuff guys
good info for all resulting :D
v
vvega
Postby TWSTD » Mon Jul 18, 2005 1:08 pm
Im pretty sure my ST215W manual is an open diff as well - I can very easily get one rear wheel spinning when going up my car park ramp daily...
I also seem to recall the old TRD part no's for the ST215W rear LSD and the ST205 rear LSD were the same no's.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby Santa'sBoostinSleigh » Mon Jul 18, 2005 1:13 pm
when i was looking around to buy my caldina, i noticed that all the auto ones had VSC on the back windows, but the manual ones dont.
VSC is the viscus dif isnt it?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby TWSTD » Mon Jul 18, 2005 1:39 pm
no. Vehicle Stability Control.
Click here!
TWSTD
Postby Mr Revhead » Mon Jul 18, 2005 1:43 pm
yep, manuals have LSD, autos traction control and VSC
