lowering
lowering
Postby rwd_mayhem » Sun Jul 17, 2005 8:52 pm
were lowering a 30(as u do) the drivers side insert nut undone easy as. now when we tried to crack the passenger side nut it just didnt want to, the whole insert just turns, weve tried putting vice grips on the insert - didnt work, crc didnt do shit, trying to put extra weight on2 that side didnt work either.
ne1 else ever had this problem, wat did u do 2 crack the nut? ne1 got ne suggestions?
never had this problem on ne other car weve ever tried lowering.
current: 1975 Valiant Regel
rwd_mayhem
Postby evil_si » Sun Jul 17, 2005 9:03 pm
try an inpact gun, or a bit of heat on the nut,
vice grips on the insert will stuff the chrome plating,
evil_si
Postby rwd_mayhem » Sun Jul 17, 2005 9:21 pm
we dont have access 2 an impact gun, how can i heat the nut up? blow torch or something?
rwd_mayhem
Postby evil_si » Sun Jul 17, 2005 9:25 pm
is it still in the car?
you could take the entire strut out and go to a mechanic that might be nice enough to try for you,
other wise yea oxy acetylene, not to much heat, just on the out side of the nut, dont heat the shaft and be quick when you undo it.
cant think of any other ways, if youve already tried vice grips chances are youve already damaged the chrome so go hard, use good quality vice grips, and very tight.
evil_si
Postby rwd_mayhem » Sun Jul 17, 2005 9:35 pm
my mate works at a garage i mite have 2 use him lol
rwd_mayhem
Postby wde_bdy » Sun Jul 17, 2005 11:27 pm
Normally the top spring hat locks onto the insert shaft. If that is still in place there is normally a hole you can slip a large screwdriver in for more leverage.
Callum
wde_bdy
Postby rwd_mayhem » Mon Jul 18, 2005 11:37 am
where is this hole? on the shaft?
ill have to go and check it out.
rwd_mayhem
