We are 80% through the process of wiring up the standard ECU for the 3tgte in my KE36 but have come to a dead end and need sum expertise.
What i need to know is where the 4 wires off the ignitor (see top link below) go to, the only wiring diagram i have been able to find (bottom link below) shows the wires as being (G) green, (GW) green/white, (B) black and (Br) brown,where as the wires coming off my ignitor are blue,green,pink and yellow
If we are correct one of the wires in one of the pairs (guessing the green and blue wire pair) is the IGF wire (tells the knock computer what the dwell angle is?) and the other being the IGT wire (sends a signal from the knock computer and tells the ignitor to either advance or retard the timing?)
Again if we havnt got this totally wrong,the second pair of wires (the yellow and pink wires going to the green plug) are rpm signals with one wire going to my rev counter and the other wire sending a high voltage signal (over 150volts) to the ECU which then converts the voltage signal into a RPM signal??
So what we need to know is which wire goes to where,has anyone else got a different knock computer wiring diagram to the one we have?
Any help would be greatly appreciated!!
http://i11.photobucket.com/albums/a182/ ... ter001.jpg
http://i11.photobucket.com/albums/a182/ ... agram2.gif
