Can I easily put a 6speed BZ-R Box on my BZ-G 5speed Levin?
- Graphite
- Toyspeed Member
- Contact:
I've decided I need a gearbox with LSD, so was wondering if I can do this without any dramas? or would I also needs the BZ-R ecu etC?
not all the 6 speed boxes have lsd.
Apparantly the BZ-V comes with an LSD 5 speed.
Re: Can I easily put a 6speed BZ-R Box on my BZ-G 5speed Lev
Graphite wrote:would I also need the BZ-R ecu?
You dont need the ecu to run the 6 speed but there is a difference between the 5 & 6 speed, the 6 speed has premature rev cut points in 1 st and 6th gear and slightly changed timing curves for a split second after lift throttle and reapplication to ease and protect the 6 speed's synchro and reduce driveline lash.
- CozmoNz
- Toyspeed Member
- Contact:
Bazda wrote:not all the 6 speed boxes have lsd.
Yeh, and they are common.... ive only seen about 3 in dunedin, inc mine (well, my old one now i guess). NOT,
but there are about 4,000 Bz-G's
some Bz-g's had lsd's too though......
Rayne For President!
Bazda wrote:Apparantly the BZ-V comes with an LSD 5 speed.
Don't presume this to be the case. All written matter might indicate that BZ-V's have LSD but we've had 3, that I can recall, in stock, none of which had LSD's.
It would be easy to suggest that they've all had gearbox changes at some stage but I think that's a bit too much of a coincidence.
As with everything, check it out before parting with your money.
- Mr Revhead
- SECURITY!
- Contact:
Have done this so here are the pitfalls
Top box mount needs butchering,
You will need the linkages AND shifter pedastal with the 6speed, 5 speed items do not work, i have tried. prepare for fun getting the linkages out from under the dash! think that is all, good luck
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
- Mr Revhead
- SECURITY!
- Contact:
levin_it_large
- Toyspeed Member
- rallymazda
- Toyspeed Member
- Mr Revhead
- SECURITY!
- Contact:
