Can I easily put a 6speed BZ-R Box on my BZ-G 5speed Levin?
Graphite
Contact:
Post by Graphite »
I've decided I need a gearbox with LSD, so was wondering if I can do this without any dramas? or would I also needs the BZ-R ecu etC?
Post by Alex B »
what is the bzr box btw? id assume its C6x or maybe E6x
aesc
Post by aesc »
C160 I believe
EX AE101 owner
2013 Ford Focus ST
Post by sergei »
I've done it in my AE101, the only thing I had to modify is the left gearbox mount (bend/drill holes)...Althou you might have slight problem shifting in reverse (too hard - not enough left right movevent of shifter)
Contact:
Post by Bazda »
not all the 6 speed boxes have lsd.
Apparantly the BZ-V comes with an LSD 5 speed.
Contact:
Re: Can I easily put a 6speed BZ-R Box on my BZ-G 5speed Lev
Post by Rick »
Graphite wrote:would I also need the BZ-R ecu?
You dont need the ecu to run the 6 speed but there is a difference between the 5 & 6 speed, the 6 speed has premature rev cut points in 1 st and 6th gear and slightly changed timing curves for a split second after lift throttle and reapplication to ease and protect the 6 speed's synchro and reduce driveline lash.
CozmoNz
Contact:
Post by CozmoNz »
Bazda wrote:not all the 6 speed boxes have lsd.
Yeh, and they are common.... ive only seen about 3 in dunedin, inc mine (well, my old one now i guess). NOT,
but there are about 4,000 Bz-G's
some Bz-g's had lsd's too though......
Rayne For President!
TRD Man
Contact:
Post by TRD Man »
Bazda wrote:Apparantly the BZ-V comes with an LSD 5 speed.
Don't presume this to be the case. All written matter might indicate that BZ-V's have LSD but we've had 3, that I can recall, in stock, none of which had LSD's.
It would be easy to suggest that they've all had gearbox changes at some stage but I think that's a bit too much of a coincidence.
As with everything, check it out before parting with your money.
Post by Alex B »
Does anyone know what these boxes go for (aprox).
Contact:
Post by Mr Revhead »
to confirm if an ae111 was fitted with an lsd from factory look at the trans code itll be c160-something-c if its non lsd itll end in an "a"
2nd hand BZ-R 6speeds go for $800ish plus. finding one can be the tricky part.
quinny
Post by quinny »
Have done this so here are the pitfalls
Top box mount needs butchering,
You will need the linkages AND shifter pedastal with the 6speed, 5 speed items do not work, i have tried. prepare for fun getting the linkages out from under the dash! think that is all, good luck
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
Xavier
Contact:
Post by Xavier »
just out of curiousity, would a 1995 trueno bzg automatic has a LSD??? :D
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Contact:
no
Post by sergei »
hmm strange, I guess AE111 5speed gear shifter is shorter then on AE101, It works on mine (well Reverse is a bit pain)... What is exactly difference between 5speed linkages and 6 speed linkages?
quinny
Post by quinny »
The retaining clips holding linkages into pedistal dont line up and the 5 speed didnt have enuf left to right swing to hook reverse
levin_it_large
Post by levin_it_large »
you could expect to pay upwards of 2g's - they aren't very common and they can charge what ever they want really.
quinny
Post by quinny »
i was offered 2g for mine but i like it too much
Post by sergei »
yeah, reverse is a bit pain. it was barely engaging in myAE101 trueno, had to bend the lever on gearbox side to shorten left to right movement...
rallymazda
Post by rallymazda »
2g?????!!!!! were are you guys shopping?
ive found them from 600 to 900, the 900 one included the driveshafts which that wreker said were different, although the otherone said they were the same so.....
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
Contact:
$600 is seriously cheap..... let me know next time you find em that cheap
Post Reply
