Degreaser - brake dust remover??
Postby SkylineObsession » Sun Jul 24, 2005 2:26 am
When i got my puncture fixed today i asked the guy if he knew how to get rid of (15 years worth) the brake dust in the inside of the rim. The outside is easy to clean on the back wheels, but the front ones have a few splotches which won't come off - and the inside of the rims has proved impossible to clean so far. He suggested i try degreaser?
I know you don't immediately see behind the outside of the tyre into the inside of it, but i just really want to get rid of it all so it looks like it did when it left Japan. Just like the complete underside, interior and engine bay (will get them all clean eventually). The former being very dirty.
Anywho. Would this work?
SkylineObsession
Postby Alex B » Sun Jul 24, 2005 2:30 am
Yes, how bout mag wheel cleaner?
Postby SkylineObsession » Sun Jul 24, 2005 2:32 am
Didn't think they made stuff just for wheels. 8O :?
SkylineObsession
Postby Alex B » Sun Jul 24, 2005 2:36 am
we sell it at work (mitre 10) i think the warehouse etc have it too.
Postby Ae92typeX » Sun Jul 24, 2005 8:34 am
for old rims which have never been cleaned on the inside rim, ive used brush on paint stripper many times. Obvously no good for painted ones, but for plain alloy ive found it great. I use that with a stiff scrubbing brush. Brush on, wait 1-2 mins (not full strip time), scrub and hose.
Ae92typeX
Postby strap-on » Sun Jul 24, 2005 9:59 am
degreasers can work, but for the stronger stuff an acid based wheel cleaner can be ok,
traditionally you are not supposed to use this on painted wheels but for short periods of time it shouldnt hurt.
what i used to do was spray acid cleaner on , brush the ares withe a stiff brush, then spray citrus degreaser on as this is an alkaline and will help neutralise the acid, then clean off and reapeat as neccesarry.
citrus is very good stuff you can use it for alot of things, including under the hood and under your gaurds, i can get you some if you want it i have a 20 litre container sitting at home, i can try get some mag wheel cleaner cheap as well if you want.
strap-on
Postby vvega » Sun Jul 24, 2005 10:20 am
yeah dgreasers can tuen the clear coat milky
just got for the proper mag wheel cleaner
repco sells it as well :D
vvega
Postby strap-on » Sun Jul 24, 2005 10:46 am
lol i dont like the repco ones, over priced and arnt as good as something you can get for cheaper,
no offence thats just speaking from experience
strap-on
Postby vvega » Sun Jul 24, 2005 12:18 pm
lol i hate repco as well so any better cheaper procduct is all good :d :twisted:
vvega
Postby aliluya » Sun Jul 24, 2005 12:47 pm
I use Autoglym .. and that stuff is awesome .. but before i used autoglym i used toothpaste ... and that worked pretty well too ...
http://www.performance-angels.com/carcleaners.htm
2008 Toyota Highland 4WD LTD is awesome!!!
2001 E39 530i BMW
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1727
aliluya
Postby SkylineObsession » Sun Jul 24, 2005 1:02 pm
Got a few pics i took ages ago.
I'm a bit wary about using stuff that could damage the rims in any way but also on spending money on something and having it not work.
Does that citrus spray clean on its own or does it need to be helped by acid?
SkylineObsession
Postby strap-on » Sun Jul 24, 2005 4:33 pm
citrus spray cleans everything
strap-on
Postby SkylineObsession » Sun Jul 31, 2005 2:31 pm
Sweet. Is it sold in places like Repco/SuperCheap?
SkylineObsession
Postby RS13 » Sun Jul 31, 2005 3:26 pm
The citrus spray IS acid. Lots of places sell it, Repco, Butlers, Supercheap, just hunt around. Failing that, just paint your wheels black! 8)
And for the engine bay;
I wrote:And if you want extra bling in your engine bay, I got 2 cans of degreaser from Supercheap, took the battery out, covered the important-looking electrical bits with gladwrap, and went to town with the degreaser. Grab the garden hose with a high-pressure nozzle, and rinse the motor off. It dries faster with the engine warm, then go over black bits with ArmourAll!
RS13
Postby SkylineObsession » Sun Jul 31, 2005 9:13 pm
Cheers mate. Might pass on the black wheels though. ;)
SkylineObsession
Postby Silvergun » Sun Jul 31, 2005 9:55 pm
also when using the mag cleaner spray stuff its a good idea to keep it away from any plastic bits of the mags. When i used it i got some on the plastic centre cover of the mag and it totally ate through top layer of plastic ruining the centre cover.
AE92 4age Redtop
Silvergun
Postby SkylineObsession » Sun Jul 31, 2005 10:19 pm
Ah. I think mine can be taken off easily, so might do that. Thanks for the warning. :)
SkylineObsession
Postby Bling » Sun Jul 31, 2005 11:23 pm
I used silicon spray in the weekend to clean a few months worth of brake dust off my mags, wipes straight off. give that a go, can shine ya tyres at the same time :lol:
Postby strap-on » Sun Jul 31, 2005 11:57 pm
RS13 wrote:The citrus spray IS acid.
no it isnt..
pacer wrote:Citrus cleaner is a concentrated alkaline cleaner with added D-limonene (processed orange peel) for cleaning dirt, grease and grime. Ideal to clean tyres, wheels, under bonnets, door jambs and engines. Also perfect for cleaning floors, stoves, benches, baths, showers and toilets.
last time i looke alkaline meant the oposite to acidic
strap-on
Postby slammed_integral » Mon Aug 01, 2005 12:08 am
im a tyre guy and trust me brake cleaner spray works fully.
spray it on wait like 3 seconds, use a dry rag and rub the desired spot clean.
I have to do it all the time for applying stick on wheel weights for mags
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
