Degreaser - brake dust remover??
Postby SkylineObsession » Tue Aug 02, 2005 12:05 pm
Eeny, meeny, miny, mo. 8O I'm going to take a look today probably so hopefully these things aren't too expensive.
SkylineObsession
Postby SkylineObsession » Tue Aug 02, 2005 6:23 pm
Ended up buying CRC 'Brakleen'. The be's good enough i hope. :?
SkylineObsession
Postby blackie » Wed Aug 03, 2005 1:38 pm
yeah that stuff is pretty strong
blackie
Postby SkylineObsession » Wed Aug 03, 2005 1:45 pm
But not strong enough. :(
Bloody h*ll man. This stuff seems to be permanantly stuck on! :x
The only thing the Brakleen properly cleaned was the back of the muffler (which is now shiny again). But i think it was only dirt on it.
I give up. The only thing that could remove this stuff by the looks of it is some sort of metal polishing equipment (i was out there for about an hour or more). :cry:
Waste of $14.00.
SkylineObsession
Postby Ae92typeX » Wed Aug 03, 2005 7:37 pm
take the wheel off and spray, let soak, hit it with a stiff plastic scrubbing brush, rinse, repeat...should be better.
just like with cleaning engines, often just the spray isnt enough by itself, especially when its caked on over the years in places like like inner mags.
Ae92typeX
Postby SkylineObsession » Wed Aug 03, 2005 8:06 pm
Yeah i took one of the wheels off and sprayed it (they spray drys surprisingly quick). I tried a plastic brush (like the ones used to clean dishes, but with stiffer bristles) but even after hard scrubbing and repeated spraying it barely took anything off. A rag seemed to do a better job than the brush (but still not that good a job).
Do you think a polisher/buffer thingy would help - something that wouldn't take the paint off?
SkylineObsession
Postby aliluya » Wed Aug 03, 2005 9:38 pm
Try some toothpaste ... you gotta have some of that already .. just get some and try it ..
2008 Toyota Highland 4WD LTD is awesome!!!
2001 E39 530i BMW
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1727
aliluya
