brake pads installation, rotor not fit back
Postby Fred » Wed Aug 03, 2005 9:00 pm
Heya all, just trying to do a brake pad change on the front of the ae92
taken it all out and stuck the new pads in but now the calliper doesnt fit back on, the outside brack pad seems to be to big
i dont know how to put images on here so ummm, il put it in my profile picture or can email
White Trueno ae92, 4agte
172kw atw and as bazda put it "lowest reading dyno in auckland"
http://toyspeed.blakjak.net/profiles/profile.php?id=672
http://www.cardomain.com/ride/2124212/1
Black and Gold Trueno ae92, 4agze
14.6@152 (hmmm thats a .69)
http://www.cardomain.com/ride/2160441
Fred
Postby Spannergal » Wed Aug 03, 2005 9:17 pm
did you push the caliper piston/pistons back before trying to put it back into position.
caliper brakes are self adjusting, so the pistons move out as the brake pad wears
Spannergal
Postby Fred » Wed Aug 03, 2005 9:52 pm
yea the piston has been pushed all the way in, and the brake pad thats on the inside is not the problem as it can be pushed beyond the point of no return so that the rotor hits the caliper itself, its the brake pad on the other side that seems to be the problem
Fred
Postby Fred » Wed Aug 03, 2005 9:53 pm
also i undid the niple thingie to let the pressure out so i could push the piston all the way back, does this mean that i have to bleed the breaks or should it be fine, and only need to bleed breaks if the hose is taken off? thanks
Fred
Postby Ae92typeX » Wed Aug 03, 2005 9:57 pm
if you undid the bleed nipple you will need to bleed the system.
it good practice when doing a pad change anyway.
Ae92typeX
Postby crnkin » Wed Aug 03, 2005 10:36 pm
from memory i had the same problem, the thing we found was the other side screwed in, before you put the pads on- if that makes sense?
deaf_homo "currrently yes"
crnkin
Postby 85AW20v » Thu Aug 04, 2005 11:40 pm
You might also find that the caliper is sticky on the rods that they slide onand they just need a bit of lubing so they move freely.
See ya
Simon
85 MR2 20v
85AW20v
Postby Fred » Fri Aug 05, 2005 12:53 am
so by saying that i presume that the entire caliper can be spread open more? so that the outer brake pad moves further apart, if thats the case then the issue should be sorted, do you have to tighten/loosen the bolts on the rods? or should just pushing it apart do the job? i dont want to try force it open more if its not meant to
Fred
Postby GT4 20 » Fri Aug 05, 2005 8:33 am
Don't take this the wrong way, but should you really be doing your own brake work if you are getting stuck on something as basic as this? We all have to start somewhere, but usually an idea to get someone who knows what they are doing to take you through the process of what to do. Then you'll know when you do it yourself.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Fred » Fri Aug 05, 2005 12:29 pm
haha yea, have been through them with someone before, and have just slaped on the old ones again
Fred
