Engine questions
Postby Adamal » Sun Aug 07, 2005 8:44 pm
Hmm... That shouldn't be too bad. Hit full boost around 4000RPM?
Postby bzr_turbo » Sun Aug 07, 2005 8:58 pm
nah 5000rmps usally
bzr_turbo
Postby Adamal » Sun Aug 07, 2005 9:13 pm
That could be your problem there. Might be that the turbo is a bit too big for your engine to give you a broad power band.
Below about 4000RPM would be less powerful than if you didn't have the turbo, due to being a lower compression for the boost.
Plus, if its at full boost by 5000RPM, you'd have a very narrow power band, around 2000RPM, as it would probably start to drop off after 7000RPM, maybe 7250RPM.
If you had a smaller turbo, or maybe different turbo internals (I don't know much about wheel trim etc, maybe vvega can fill in the blanks), you'd have a boarder powerband, although you wouldn't have as much peak power. Which is something a lot of people don't understand. Peak power isn't everything!
Postby bzr_turbo » Sun Aug 07, 2005 9:16 pm
i agree man im upgrading soon thanks for advice :)
bzr_turbo
Postby EVLGTZ » Sun Aug 07, 2005 9:50 pm
bzr_turbo wrote:I didnt mean like 10 second difference I was meaning like 1 sec witch is alot to me :oops:
Sorry bout the confusion guys
what times are you pulling bzr_turbo?
Should be able to deal to a type r unless its turbo as well
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Malcolm » Sun Aug 07, 2005 10:12 pm
or unless he's full of sh*t and doesn't have a turbo? Image
Postby Ae92typeX » Mon Aug 08, 2005 12:44 am
bzr_turbo wrote:Most of car with TRD setup...
can you elaborate on what trd stuff you have done? like turbo'd atlantic or something?
Ae92typeX
