SAFC 4AGTE
SAFC 4AGTE
Postby willsf1 » Sat Aug 06, 2005 7:45 pm
Was wondering if anyone has tried running an apexi SAFC Gen 1 on a 4agte? Would it be possible to run after market injectors say 440's instead of using an extra injector and powerlink?
never drink and drift
willsf1
Postby Elmendorf » Sat Aug 06, 2005 9:16 pm
I use a gen 1 SAFC on my 4EF-TE I know the engines are different but I have put larger injectors in and the SAFC runs them fine without the need for any extra injector etc.
Hope this helps.
Elmendorf
Postby Akane » Sat Aug 06, 2005 10:58 pm
I do not recommend this.
Postby loose_unit » Sun Aug 07, 2005 1:53 am
Running 315's over a Stock 295 wouldn't be a major task to achieve, but 440's on a 4agte might be a little harder.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
hmm
Postby ezy10s » Sun Aug 07, 2005 11:17 am
what setup are you running (or about to run) turbo- ecu etc?- lmight have a better solution for you depending on what setup and power you looking for
Member #244
Gone fishing until further notice
ezy10s
Postby 1598cc » Sun Aug 07, 2005 4:31 pm
yeh a safc will work well, but the more % decrease the more your timing gets advanced, so you may have to retard the dizzy slightly.. dudes use em on hondas all the time , upgrading from stock 240cc injectors to 450cc
4agze injectors are around 365, so some vr4 injectors would be good.
1598cc
Postby Elmendorf » Sun Aug 07, 2005 5:34 pm
At the end of the day it all comes down to how well you get it tuned 8)
Elmendorf
Postby willsf1 » Sun Aug 07, 2005 10:22 pm
Im doing a 4agze -gte conversion td04 15psi max but want to look in to a fuel system to support a td05 and extra boost. I was thinking supra or vr4 injectors with the afc???
willsf1
Postby Bazda » Sun Aug 07, 2005 11:44 pm
safc will just increase the timing too much and cause it to detonate.
Better option is a powerlink extra injector controller.
Postby loose_unit » Mon Aug 08, 2005 12:48 am
For not a huge amount more than a SAFC you could get a link.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby Elmendorf » Mon Aug 08, 2005 7:49 am
loose_unit wrote:For not a huge amount more than a SAFC you could get a link.
Not if hes using a gen 1 :roll:
Elmendorf
hm
Postby ezy10s » Mon Aug 08, 2005 8:47 am
willsf1 wrote:Im doing a 4agze -gte conversion td04 15psi max but want to look in to a fuel system to support a td05 and extra boost. I was thinking supra or vr4 injectors with the afc???
which ze ecu are you running- AFM or Map(the map one will boost cut at 14-15psi)
Member #244
ezy10s
Postby evil_si » Mon Aug 08, 2005 9:57 am
dont use a tdo4 over 13psi, they have a tendancy to snap shafts,
imo a td04 is too small and a waste of time on a 4agte.
evil_si
Postby FLAWLES » Mon Aug 08, 2005 10:20 am
if your woried about controling fuel and are looking at an better option look at this place
its my uncles and stev murchs
www.performancemotorresearch.co.nz
FLAWLES
Postby Malcolm » Mon Aug 08, 2005 10:45 am
AFAIK the MAP ecu, although it removes the AFM (on an AFM motor), as far as fuel control goes, it's in the same boat as the SAFC, if you put bigger injectors in, and consequently have to lean the a/f out, it'll advance timing which is the enemy of boost.
And why don't they have a price on the website?
Postby FLAWLES » Mon Aug 08, 2005 10:50 am
mm i dont now why they dont show a price :? i think you have to go through the dealers both in nz and the states
but i got mine for free :P
and i realy dont see anything wrong wirh it
the guys that i have talked to in the states that are running them on 500+hp supras think the word of them
they reckon there better than the hks ecifilent
but i realy dont now never had an hks ecu
FLAWLES
Postby 1598cc » Mon Aug 08, 2005 11:32 am
yea buy this!.. ran it on my 4agte at 18psi and worked mint. \
http://www.trademe.co.nz/structure/auct ... d=32980676
1598cc
Postby willsf1 » Mon Aug 08, 2005 9:45 pm
Thanks for the input looks like an extra inector and powerlink will be on the cards soon!
willsf1
