Wheel-arch/Wheel clearance... roll out the best remedy?
Postby Soulhaven » Wed Aug 10, 2005 9:18 pm
What is the best thing to do when you've lowered your car (sport low) and then put bigger wheels on, and now have a little rub between the arch and the wheel on some bumps??
The garage that fitted the wheels say they could do a little panel work to roll out the arches a little, with a small risk to the paint.
What have other people done?? Does this sound like a fair option to take?
Also... does anyone know if I'm likely to strike troubles at WOF time?
Soulhaven
Postby Lloyd » Wed Aug 10, 2005 9:51 pm
Get the guard rolled (basically roll the lip up on the edge) if thats where its actually rubbing. Most panel beaters should do it for a small fee, best to ask a couple to get an idea of price. No issues with warrents, most really low cars will have this done
If its rubbing on something other than the lip on the guard then you'll have to find out where exactly its rubbing and get someone to have a look at it
Postby pervert » Thu Aug 11, 2005 9:29 am
Or if you want to do it yourself...
Put a couple of large people in the back, and stick a baseball bat or something similar up between the tyre and the guard and gently roll the car back and forwards turning the bat.
Drive and test, and repeat until fine.
...or just do what I did and use a hammer... :lol:
pervert
Postby EVL GSXR » Thu Aug 11, 2005 9:58 am
pervert wrote:Or if you want to do it yourself...
Ha ha ha ha that's what's I had to do (Steal Pole) once I put the adjusty's in the GT but it was to flare the guard's out as the lip had already been done all by my mate who is a panel beater of course.. Work all good part from was hitting right in the top of the inner gaurd :S
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby pervert » Thu Aug 11, 2005 11:31 am
I've got a KE70 sitting near-on cut bumps on 205's and it's impossible to make it rub anywhere, even with 3 in the back...it took a lot of testing... :lol:
All done with a hammer and a baseball bat, minimal paint damage too...
pervert
Postby Santa'sBoostinSleigh » Thu Aug 11, 2005 11:32 am
pervert wrote:...or just do what I did and use a hammer... :lol:
rangi styles :D
if you do this be careful of fux0ring the paint tho
my mate had a starlet with 16s (and crappy soft springs) that was rubbing on a bolt right down the bottom of the arch, on the rear of the car. he lipped his guards (rangi styles) and stuffed his paint - which of course made no difference because it was the bolt, not the lip.
as mentioned before, check it out properly before you start bashing :twisted:
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby pervert » Thu Aug 11, 2005 12:01 pm
If you've just lowered it and it is rubbing in the rear, especially on a more modern car...it is usually the guard lip.
But yes, it would be a good idea to double check before you start getting too serious.
pervert
Postby EVL GSXR » Thu Aug 11, 2005 1:56 pm
rangi styles :D
Yeah when I dropped my Starlet and threw 18's on it it was rubbing
real bad ended up cutting the plastic on the Petrol Flap Side as was rubbing on the Tyre then Cut the Rear Seat Belt Bolt's as they were rubbing on the inside of the tyre when going up angled drive way's etc..
www.lowndvs.co.nz
EVL GSXR
Postby Santa'sBoostinSleigh » Thu Aug 11, 2005 2:34 pm
EVL GSXR wrote:Yeah when I dropped my Starlet and threw 18's on it it was rubbing
starlets with big wheels just look wrong - theyre too small fro big rims! (IMHO)
Santa's Mega Sale
Postby EVL GSXR » Thu Aug 11, 2005 2:38 pm
Lye's they look fine I was happy with the way it looked and when the adjusty's went in was even happier.. Plus the bigger rim's gave bit more traction well from 3rd gear onward's :D :D
www.lowndvs.co.nz
EVL GSXR
Postby Fraud » Thu Aug 11, 2005 2:52 pm
Whaddya want traction for?! :lol:
I started mine with a power bar with a strong handle and then used hammer and dolly.
Now it rubs on the indent for the door to close into :x
Fraud
Thanks all for advise
Postby Soulhaven » Sat Aug 13, 2005 1:20 am
Done the wheel arch roll out. All is well, just a little paint in under the arch has cracked a wee bit... will tidy that up to prevent rust. Got some mates in the back tonight for a cruise, no scraping noises! Excellent.
Soulhaven
