ae86 brake upgrades
ae86 brake upgrades
Postby gepsk8 » Mon Aug 08, 2005 1:03 am
im searching for the forum on nissan skyline brakes m-spec on to front of an ae86,
any help will be helpful
thanks
gepsk8
Postby fangsport » Mon Aug 08, 2005 9:27 am
i have tried this and there was too much nutting out to do. but then, i was in a rush with an event coming up and i am a bit impatient.
due to the fact that the 4 pot caliper is so wide, large spacers would need to be used, or a deeper offset on the disc was required. i believe that the conversion could be done along similar lines as the Hi-lux 4 pot conversion as the calipers are a similar dimension.
fangsport
Postby Rick » Mon Aug 08, 2005 6:08 pm
If you upgrade your AE86 brakes can I buy them off you??? :P
Postby JamesM » Tue Aug 09, 2005 2:22 am
i have done this on my 86.
there is a few different ways u can do it.
s13 gear with custom hubs. cressida front struts and arms? or keep factory and use adaptor plates.
havent done the cressida way myself but they all involve a bit of work. would stick to soemthing more bolt on if i was to do again in the future. not worth the effort in most cases.
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby gdsup » Tue Aug 09, 2005 7:47 pm
Josh Young who was over from aussie for the last d1nz round seemed to think quite strongly that usiing proper aeg86 front parts was the go, he said miost guys over there had used the gx60/70 stuff and then swaped back, apparently the geometery on the stub axle and where the steering knuckle on the lower arm sit are different to ae85/6 and dont work so well, likewise he said that every one that had changed to s13 type front had also since converted back to ae86 front... having driven alot and of ae's and having driven them well i believe alot of what he says.....
But back to the point, dont change struts just make adaptors for larger brakes, i run fc rotors and 4 pots on mine, seems great
gdsup
Postby JamesM » Tue Aug 09, 2005 8:03 pm
yea id agree with u there.
when u say adaptor plates .. u just mean the bracket to hold the caliper right?
Team Megasquirt
1984 AE86
JamesM
Postby gdsup » Tue Aug 09, 2005 8:23 pm
yip
gdsup
Postby jones » Thu Aug 11, 2005 8:30 pm
i know of a ae86 using early rx7 brakes
u cant hang with jesus
jones
Postby Xyrath 86 » Thu Aug 11, 2005 8:49 pm
Or if you got some bling ya can get some of these beasts.
http://www.technotoytuning.com/t3_site_ ... rakes.html
Xyrath 86
Postby Rick » Thu Aug 11, 2005 10:00 pm
HOLLY CRAP! 8O 8O 8O 8O They are BIG 8O
Postby JamesM » Fri Aug 12, 2005 12:42 am
no they rnt..
mine are bigger. r33 gts25t brakes.
Team Megasquirt
1984 AE86
JamesM
