whats the quickest way to tell if a car has an lsd box?
Postby phatman3801 » Fri Aug 12, 2005 2:44 pm
is there a way to tell if a car has lsd apart frm trans codes etc?
current project/ride: BZG levin
phatman3801
Postby Carlos » Fri Aug 12, 2005 2:58 pm
Jack the car up, put it in neutral, turn 1 wheel by hand - the other wheel should spin the same direction. This works on a rwd - dunno about fwd
Don't tell anyone, but I bought a Corolla so I could beat some Hondas on TvH days :P
Carlos
Postby Dell'Orto » Fri Aug 12, 2005 3:03 pm
Or put one wheel on your lawn, the other on your drive way, and sidestep the clutch at 6 grand :lol:
Postby pervert » Fri Aug 12, 2005 3:16 pm
Yeah, just do a skid... :lol:
pervert
Postby blackie » Fri Aug 12, 2005 3:46 pm
skiddies :lol:
a lot of cars u can look at the transaxle code on the firewall to tell, although older cars could have had replacement gearboxes put in
blackie
Postby Distrb » Fri Aug 12, 2005 3:53 pm
Carlos wrote:Jack the car up, put it in neutral, turn 1 wheel by hand - the other wheel should spin the same direction. This works on a rwd - dunno about fwd
that only works if you have a viscous type doesnt it?
as with a plate/torsen type you need drive to tighten the plates in order for the lsd to work.
coz i can jack up the rear of one of gadgets rz supras (with torsen lsd) and turn one wheel and the other wheel stays static or turns the opposite way
Mmm, Boost wrote:Or put one wheel on your lawn, the other on your drive way, and sidestep the clutch at 6 grand :lol:
i reccomend this method for sure :D make sure theres no fences/bushes or houses in the way tho :oops:
Distrb
Regular Poster
Postby Bling » Fri Aug 12, 2005 4:55 pm
yeah and results will be as follows:
just a brown skid where grass used to reside: non-LSD
same brown skid as above + bonus black skid on concrete = LSD
dilma: do try it :lol:
Postby CEvans » Fri Aug 12, 2005 8:00 pm
just gas it off an intersection in the wet. u shud b able to feel both whells spining and not loose too much traction plus a non lsd will lite up easily while corning too.
best idea of all the is the grass one.
CEvans
Postby fangsport » Fri Aug 12, 2005 8:34 pm
BZG|Bling wrote:yeah and results will be as follows:
what about the brown skid in ya Jockey juniors when the fence attacks ya??
fangsport
Postby phatman3801 » Fri Aug 12, 2005 10:12 pm
ive also been told jack the car up, put in neutral, sum1 hold one wheel and sum else try to turn the other wheel, if lsd the guy trying to turn the other wheel will be able to, if no lsd when the guy trys to turn the wheel he will hav to fight against the other guy holding the wheel, is that right???this is what a mate has told me
phatman3801
Postby fx gt » Fri Aug 12, 2005 10:15 pm
nah,just do a big skid,if some one complains it was Mmm, Boost's folt :)
fx gt
Postby phatman3801 » Fri Aug 12, 2005 10:18 pm
already been done for "loss of traction" resulting in losing licence:P plus its not my car so beeta not
phatman3801
Postby CozmoNz » Sun Aug 14, 2005 12:30 am
put it nose first into a ditch, with 3 wheels in the air, one hard down in the ditch.
If you can reverse out, Its lsd
If you only spin the outside wheel, its not ;).
thus, my trueno is lsd!
Rayne For President!
CozmoNz
Postby Bling » Sun Aug 14, 2005 1:04 am
u got photos of it with 3 wheels in the air.... or can u do a 'paint' version, sounds almost impossible to do :P sounds interesting tho :lol:
Postby CozmoNz » Sun Aug 14, 2005 1:49 am
as you can see, the car is "nose first" into the bank, with the arse end up, there is a ditch, in which the car went down into first, before plouging itself *up* (i guess it did a wee hop off the ridge into the bank).
but people leaning on the boot / rear, and me reversing, it drove right out.
CozmoNz
Postby Bling » Sun Aug 14, 2005 3:11 am
daaamn
good effort to get out of that,
and good stuff with the image too :lol: :lol: :lol: :lol: :lol: :lol:
Postby KinLoud » Sun Aug 14, 2005 11:14 pm
My understanding of a torsen diff...
If one driven wheel is not touching the ground then there will be no torque transmitted to the other wheel.
The torsen (i think) transfers 5(?) times the torque to the non slipping wheel. So if wheel in air, torque = 0 ...... 5 times 0 = 0
On grass - you will get torque transferred to other wheel, but not heaps
On tarmac loads of torque transferred = happy driver
Ken
Ham
021 408 863
Postby levin_it_large » Mon Aug 15, 2005 7:58 pm
i thought levins had a viscous LSD.
levin_it_large
Postby CozmoNz » Mon Aug 15, 2005 8:00 pm
they do
the likes of late model supras (mk4 styles) etc have them.
CozmoNz
Postby sergei » Mon Aug 15, 2005 8:20 pm
late model supra is torsen
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
