4age Oil pressure gauge sender unit questions
Postby KwS » Mon Aug 15, 2005 12:59 am
Right. mate bought an 84 AW11 MR2.
It has a bluetop 4age in it.
We have a problem though. We found the wire that runs to the stock pressure gauge just sitting around in the engine bay. not plugged into anything.
We used good old searches to find the "pressure sender" which is next to the oil filter, and next to the exhaust manifold and the A/C pump. little round brass thing apparently. Thats there, we have had a look at it (hard to see though).
Where does the wire for the stock oil pressure gauge plug into? anyone got pics of it plugged in?
Cheers.
KwS
Postby Ae92typeX » Mon Aug 15, 2005 12:53 pm
looking at the sender, on the top of it it has a little dimple, the wire plugs/slides onto that.
Ae92typeX
Postby 85AW20v » Mon Aug 15, 2005 1:24 pm
Also, if its a small sender unit much like a temp one the oil pressure gauge won't work - those are for a light. You need the one that has a chamber about 40mm in diameter and about 30mm high on it. The wire slides onto the nipple as mentioned.
See ya
Simon
85 MR2 20v
85AW20v
Postby KwS » Mon Aug 15, 2005 7:27 pm
Cheers for that guys. Got it all working today.
Damn that sender is a bitch to get at when the wire comes off and you cant be bothered removing the dizzy, lol.
KwS
Postby no_8wire » Tue Aug 16, 2005 9:31 pm
My aw11 (1988) doesnt have a oil pressure gauge? :?
no_8wire
Postby Pelo » Wed Aug 17, 2005 11:14 pm
Really?? Thats strange... what gauge do you have in the top RH corner of your gauge panel?
Pelo
Postby no_8wire » Thu Aug 18, 2005 1:47 pm
I noticed after I had posted that , wait a sec it says L not C...
I thought it was a oil temperture gauge :oops:
no_8wire
Postby Pelo » Sun Aug 21, 2005 10:34 pm
:P
My oil temp gauge and water temp gauge dont work... there are quite a few loose wires hanging round it is scary! where is the water temp gauge sender?
Pelo
Postby Ae92typeX » Mon Aug 22, 2005 11:56 am
Pelo wrote::P
Unless its another temp sender, the gauge temp sender is located on the front left of the block...which on a m2 means the rear right hand side by the inlet man.
Ae92typeX
