How do you fix engine run on
Postby bogjob_kp60 » Mon Aug 15, 2005 5:01 pm
When I turn my starlet off (4k twin carb) it shuders for a while. Its really anoying and sometimes imbarasing. Its done it so bad once that smoke started pouring out of the carberators. Iv been told to inspect the head and to sand sharp edges in the head. Before i go plowing on in there could someone confirm this?
bogjob_kp60
Postby Jebus » Mon Aug 15, 2005 5:04 pm
Quick fix is to let it idol for a little bit before you turn it off, and it wont run on.
Jebus
Postby TrouserFxGt » Mon Aug 15, 2005 5:52 pm
or if it diesels really bad and you cand be fecked cleaning all the carbon and crap off the pistons/head then stall it by leaving it in top gear and letting the clutch out.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Crimson Tears » Mon Aug 15, 2005 6:38 pm
Incorrect ignition timing, too rich mixture, faulty anti dieseling solenoid could all cause the problems you're describing. I'd be more inclined to look at the simple stuff before you pull the motor to pieces and start modifying it.
Crimson Tears
Postby fatgtr » Mon Aug 15, 2005 6:57 pm
Crimson Tears wrote:Incorrect ignition timing, too rich mixture, faulty anti dieseling solenoid could all cause the problems you're describing. I'd be more inclined to look at the simple stuff before you pull the motor to pieces and start modifying it.
yep definately start there
James
gotta love the punk music
fatgtr
Postby Mr Revhead » Mon Aug 15, 2005 7:01 pm
yeah... could be as simple as incorrect timing.....
Postby thaphatty » Tue Aug 16, 2005 7:16 pm
yeap check idle speed and idle mix needles first
thaphatty
Postby bogjob_kp60 » Tue Aug 16, 2005 11:52 pm
Cheers for the advice. I find im useless enough tuning single carbs let alone twins so iv booked in in for a tune, timing and compresion test
bogjob_kp60
Users browsing this forum: Bing [Bot] and 13 guests
