t0ms said:
If you do want to run two batteries on a standard alternator go and buy a VSR (voltage sensitive relay) they are designed for marine applications (available at places like burnsco)
what they do is supply current to charge the second battery only when the first one is charged. this will mean that even if you run the stereo hard enough to flatten one battery the second one is still ok. the first will only charge after the voltage has come back up after you start the motor and get some charge back in the main battery.
