Mystery 3S Piece..
Mystery 3S Piece..
Postby EssDub » Mon Aug 15, 2005 9:16 pm
Can anyone tell me what this is? (circled in YELLOW) It's causing a high idling problem with my car, its unplugged for the moment, and its running fine, but i want to know what it is :?
Cheers in advance :)
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby sergei » Mon Aug 15, 2005 9:24 pm
a/c or electrical load idle up
Postby EssDub » Mon Aug 15, 2005 9:32 pm
ah yup :) What does it do exactly?
EssDub
Postby Alex B » Mon Aug 15, 2005 9:33 pm
sergei wrote:a/c or electrical load idle up
Prety self explanitory.
Makes the car up its idle up when its under load...
Postby EssDub » Mon Aug 15, 2005 9:35 pm
thing is, even when theres no load, it idles fine. as soon as you give it any amount of throttle, it takes the idle to 1600rpm and doesnt come down unless i move the plug :?
EssDub
Postby Alex B » Mon Aug 15, 2005 9:36 pm
What happens when you turn on the AC with it unplugd?? Slight idel up or does it shudder and not sound to happy??
Postby EssDub » Mon Aug 15, 2005 9:38 pm
nothing happens when i hit the A/C, lol only the light comes on by the switch. no rev change at all, even when plugged in.
EssDub
Postby Alex B » Mon Aug 15, 2005 9:40 pm
Ha so the AC not turning on then?? Then id assume its the AC idel up control.
Postby EssDub » Mon Aug 15, 2005 9:44 pm
if it is, then my system probably needs gasing up :roll:
but even with the AC going, 1600rpm seems way too high for that considering every other car ive seen using it the idle goes to about 1100rpm max...
Anyone got a spare one i could pinch? :P
EssDub
Postby AJz » Mon Aug 15, 2005 10:07 pm
EssDub wrote:if it is, then my system probably needs gasing up :roll:
my aircon needs gassing up to, but it is 16 years old, so that doesnt surprise me.
I had vtax :(
AJz
Postby samlloyd » Tue Aug 16, 2005 5:06 pm
on the same topic, my mr2 has the a/c button with an awesome little green light in it, but do i even have ac?
which hoses are they? :oops:
(car is getting h/gasket done so cant go and check if i have this or that)
please help!
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby no_8wire » Tue Aug 16, 2005 9:34 pm
go check at the front of the car...does it have what looks like two radiators?
if so .....yes
no_8wire
