anyone know wat does this do?
http://cgi.ebay.com/ebaymotors/Twin-Pow ... 7990700516
it said it will adjust the air intake, would it makes the engine running too rich or too lean? some advice pls
well i am not buying from them... just wanna know would that thing makes the engine run too rich or too lean...NA Drifter wrote:I bet it said "Made in Taiwan"...
as I saw some when I went for travelling in Taiwan..
but I don't believe they will give u more power.. and they ain't that cheap.. it just don't make sense to me going to give u abit more hp.
where would the idle screw be in black top 20v???vvega wrote:it dose the same thing as ajusting the idle screw :S
i guess some people will by anything
v
Xavier wrote:where would the idle screw be in black top 20v???vvega wrote:it dose the same thing as ajusting the idle screw :S
v
Xavier wrote:just wondering how come there r such product on the market??
Silent Knight wrote:Xavier wrote:just wondering how come there r such product on the market??
Because just like many other bullshit products out there like electric BOVs and the lot there will always be stupid morons forking out money for teh bling.
thanks NA Drifter, that is the answer i am lookin for...NA Drifter wrote:Xavier wrote:just wondering how come there r such product on the market??
well, you been tempted to buy it didn't you?, also it look "good" and something that's DIY. easy to install and give you more hp*.
so people will want to buy such products!!![]()
But when you think/know how and engine work etc, it will not give u much hp, but it "may" give you better trottle response!
This product will alter the vacuum in the manifold and result of that, it will alter the fuel pressure regulator too, and engine will run abit richer and "probably" will give you better trottle respone, due to factory setup is quite lean so car is realiable and better milage(less fuel being used).
that is logical, higher rev idle will not save fuel, i am not quite sure how this product works... it saids it will by pass the manifold butterfly close, just like when ur manifold butterfly is open as the engine just started from cold....vvega wrote:the only way it can alter vacum is by making the car rev higher at idle this will use more gas
v
