fitting mags
fitting mags
Postby bigfut » Sun Aug 21, 2005 5:05 pm
Just a question, is there any way to make some altezza factory wheels fit on a hiace? They are the same stud pattern, but the centre hole in the wheel is too small to fit over the centre thing (noob) on the van. Can these be machined to be bigger or would this weaken the structure of the wheel? Cheers
http://toyspeed.blakjak.net/profiles/profile.php?id=1702
The Harder You Fall The Higher You Bounce!
bigfut
Postby UTERUS » Sun Aug 21, 2005 9:53 pm
You may find you will need spacers since hiaces and hilux's use a different offset to the altezza wheels. I had tezza wheels on my ute and 20mm bolt on spacers when it came from japan.
UTERUS
Postby bigfut » Mon Aug 22, 2005 7:18 pm
oh ok, where can I get them from?
bigfut
