how do you clean off/neutralise brake fluid
Postby Mr Revhead » Wed Aug 31, 2005 12:39 pm
got a wee prob on my aw11.
the brake master cyl has leaked. because of that the paint under it is rooted. been like it for a while and the steel has started to corrode.
so what i want to know is how do i make sure that any new paint isnt going to react with the fluid and bubble up? iv heard of this being a problem.
maybe meths?
Postby Carlos » Wed Aug 31, 2005 1:40 pm
I bought this spray can stuff from Repco - under $10 for a big can from memory.
Don't tell anyone, but I bought a Corolla so I could beat some Hondas on TvH days :P
Carlos
Postby Ae92typeX » Wed Aug 31, 2005 1:46 pm
in the past ive cleaned the surface with meths/thinners, sanded, cleaned again and not had a problem of lift or reaction.
edit- often Ive also scrubbed the area with soapy water prior to the rest also.
Ae92typeX
Postby Jebus » Wed Aug 31, 2005 2:31 pm
You dont rub the area, I spray it with water from a pressure sprayer and it washes it away. Dont rub it though, thats when itll break down your paint.
Jebus
Postby Mr Revhead » Wed Aug 31, 2005 2:34 pm
hehe its been leaking for ages, the paint is already stuffed and removed!
im talking about paint that had fluid on it for months, and i need to remove the paint treat some rust and repaint
Postby ChaosAD » Thu Sep 01, 2005 7:23 pm
When we paint cars, we always use 'prepsol' to get off any oil/grease which stops the paind sticking
ChaosAD
Postby Perky » Tue Sep 06, 2005 1:43 pm
I think these are all good suggestions but I'm afraid that I can't really back that up with anything authoritative. So, FWIW I'm sure I have read somewhere that soapy water is sufficient to remove brake fluid, and also that it is soluble in meths. Of course 'Prepsol' or other grease remover is always a good idea before painting.
Perky
Postby Mr Revhead » Tue Sep 06, 2005 1:44 pm
well i used meths. gave it a couple good washes.
time will tell i guess!
