NO spark from coil *help*
Postby rwd_mayhem » Thu Sep 01, 2005 11:33 pm
ive just upgraded from a 2k to a 3k lol. now its all in and everything but it wont start, ive got petrol, thers no spark from the coil lead at all. ive looked at the coil and drawn a crude picture of my problem, or cud it b something else? all the other wires around the engine bay r connected, and ther doesnt seem 2 b 1 tht will go onto tht random wire.
what is an igniter? wher r the fuses tht cud of possibly been blown?
current: 1975 Valiant Regel
rwd_mayhem
wireq
Postby crispy'86 » Thu Sep 01, 2005 11:45 pm
i'd be saying that'll be for the power supply from the ignition switch when turned on to supply power to the ballast resistor which the other end is on
crispy'86
Postby rwd_mayhem » Thu Sep 01, 2005 11:49 pm
OK......... wher is tht, coz i cant find nethng itll plug into.
and is tht definatly my problem, or cud it b sumthng else, my mates 30 doesnt even have tht wire
rwd_mayhem
Postby gepsk8 » Fri Sep 02, 2005 12:02 am
hey, its hard to tell.
look on da starter of a termal!? for the extra wire to go on.
pm after your done that.
gepsk8
Postby RS13 » Fri Sep 02, 2005 12:41 am
Check the ballast on the firewall, those wires break all the time.. its' the white ceramic block thing on the firewall, make sure both wires are connected.. and other than that, I don't have any idea what that wire is, I've got k-series engine bay pics, and I can't see it..
RS13
Postby vvega » Fri Sep 02, 2005 7:21 am
ok so power goes into the ballest.
out of the ballest.
into the the coil psitive.
from the coil negative
and to the points
as long as you have power to the coil that will work
then you need to look at thinks like
what are the points like
are they gapped corecttly
have i connected the ht wire
have i got a condensor on the points
there4 you go
v
vvega
Postby fatgtr » Fri Sep 02, 2005 6:21 pm
ballast bypass maybe? itl stop it starting coz it wont get a full 12v if it aint plugged in to anything
James
gotta love the punk music
fatgtr
Postby rwd_mayhem » Sat Sep 03, 2005 7:18 pm
got out ther with the multi-meter n realised the coil was fukd (i susspect from the motor squashing it against the firewall lol) replaced tht wit a col lyn around n it goes all gud nw. just need 2 sort out timing.
rwd_mayhem
