4AGE cam talk.
Postby Nuty|Mike » Fri Sep 02, 2005 10:35 pm
so if i put bluetop cams in my red top tvis ill get uber more fwkw au bo ?
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby RedMist » Fri Sep 02, 2005 10:52 pm
Interesting. I thought for compressed engines you hairdryer and impeller boys went for shorter duration cams. I suppose its boost dependant, the higher the boost the shorter the duration.....
Don't ask me.. I'm an NA man!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby ChaosAD » Sat Sep 03, 2005 9:50 am
From what ive heard its:
bluetop = 240
redtop tvis = 240
redtop = 232
any gze = 232
I think ants means any NA bigport has 240 degree cams.
A lot of guys running big snails also go for bigger cams, 264 or 272 being the norm. But they set them up with less overlap than we NA guys do.
ChaosAD
Postby Mr Revhead » Sat Sep 03, 2005 10:43 am
well according to Toyotas own info its as stated in the first post.
that is bluetops have one cam. AND ALL OTHER 4AG(Z)ES SHARE THE OTHER.
Postby 92GTApex » Sat Sep 03, 2005 11:25 pm
RedMist wrote:Interesting. I thought for compressed engines you hairdryer and impeller boys went for shorter duration cams. I suppose its boost dependant, the higher the boost the shorter the duration.....
Its the overlap to stay away from if i remember correctly, not necessarily the duration
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby Bazda » Sun Sep 04, 2005 12:56 am
what i recon would work good is the bluetop n/a cam inlet and keep the standard gze cam for the exhaust (for forced induction). This in theory would work good..
Postby EVLGTZ » Sun Sep 04, 2005 6:21 pm
Bazda wrote:what i recon would work good is the bluetop n/a cam inlet and keep the standard gze cam for the exhaust (for forced induction). This in theory would work good..
yep seems to do the trick eh
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby thaphatty » Sun Sep 04, 2005 6:38 pm
when i put some bluetop cams in FLAWLES'S gze it got a further 3psi over its usual 12 = 15psi.
thaphatty
Postby vvega » Sun Sep 04, 2005 8:19 pm
thaphatty wrote:when i put some bluetop cams in FLAWLES'S gze it got a further 3psi over its usual 12 = 15psi.
im not even gunna go into why that was :D
v
vvega
Postby matt dunn » Sun Sep 04, 2005 8:44 pm
v
lol, yeah.
Wanna make it boost even more?
Just crush the exhasut so it is 1/2 blocked.
That will increase the boost in a superchaged 4AGZE too.
( but wont help performance )
Matt
Postby ants_ae92 » Mon Sep 05, 2005 1:57 pm
[quote="ChaosAD"]From what ive heard its:
bluetop = 240
redtop tvis = 240
redtop = 232
any gze = 232
quote]
Thats what I was trying to get at.
Also
4A-GELU DOHC 4/50 86 1587* 130@6600 110@5200 81 77 9.4:1
4A-GELU DOHC 4/50 86 1587 124@6600 105@5000 81 77 10:1 EU
4A-GELU DOHC 4/50 86 1587 120@6600 102@5000 81 77 9.4:1
4A-GELU DOHC 4/50 86 1587 115@6600 98@4800 81 77 9.4:1 cat, US
4A-GZE DOHC 4/50 86-90 1587 145@6400 140@4000 3.19 3.03 8.0:1
4A-GZE DOHC 4/50 86-89 1587* 145@6400 137@4400 81 77 8.0:1 JP AW11, AE92 8psi/0.56bar
4A-GZE DOHC 4/50 89-91 1587* 165@6400 152@4400 81 77 8.9:1 JP AE92 high-octane
4A-GZE DOHC 4/50 91-95 1587* 170@6400 152@4400 81 77 8.9:1 JP AE101 high-octane
Also trying to see why this is?
With less lift and duration, the red top should make its power at a lower RPM than is rated here? like the GZEs rated max power @6400rpm. Is that right, cams can effectively shift power up or down the rev range. Then shouldnt the crappy redtop make its power at slightly lower RPM If it indeed has the smaller duration cams.
With like the GZEs rated max power @6400rpm
But obviously toyota state differently to what I think here.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby ants_ae92 » Mon Sep 05, 2005 2:07 pm
Also I have an oddity that maybe Mr Revhead can explain?
I have a 1987 ae92 levin with a big port tvis. It has red top big port head and intake manifold but a 3 rib block? Did toyota ever bring out any thing like that in description?
ants_ae92
Postby Mr Revhead » Mon Sep 05, 2005 2:31 pm
maybe as chaos said, using last of the old stock.
effectivly the same engine as the block doesnt really effect anything
can you send me your full model and frame numbers?
i cant tell too much about the blocks from the epc as there is a few other changes as well. but i cant see anywhere the ae82s sharing p/n with ae92
Postby ants_ae92 » Mon Sep 05, 2005 2:57 pm
Yeah I will pm you my full model and frame numbers tomorrow morning.
ants_ae92
