RedMist wrote:Interesting. I thought for compressed engines you hairdryer and impeller boys went for shorter duration cams. I suppose its boost dependant, the higher the boost the shorter the duration.....
Don't ask me.. I'm an NA man!
Bazda wrote:what i recon would work good is the bluetop n/a cam inlet and keep the standard gze cam for the exhaust (for forced induction). This in theory would work good..
vvega wrote:thaphatty wrote:when i put some bluetop cams in FLAWLES'S gze it got a further 3psi over its usual 12 = 15psi.
im not even gunna go into why that was
v
Users browsing this forum: Bing [Bot] and 13 guests
